feeler gauges, whats what???
Old Jul 8, 2002 | 05:15 AM
01PYITR's Avatar
Default feeler gauges, whats what???
my car says .017 & .019
the gauge I just bought says .17 & .19
is this wrong and whats your thoughts?
Or did I just drink to much this past week?
Old Jul 8, 2002 | 06:56 AM
Jared's Avatar
Default Re: feeler gauges, whats what??? (01PYITR)
you got the wrong gauges.
Old Jul 12, 2002 | 11:37 AM
01PYITR's Avatar
Default Re: feeler gauges, whats what??? (Jared)
thanks I did drink too much then.
Old Jul 12, 2002 | 03:28 PM
IN VTEC's Avatar
Are you attempting a valve adjustment?
Old Jul 12, 2002 | 08:11 PM
01PYITR's Avatar
Default Re: feeler gauges, whats what??? (IN VTEC)
yup, I had a freind who is a mechanic teach me and I feel confident but the tool was wrong...
Old Jul 12, 2002 | 09:03 PM
IN VTEC's Avatar
You actually got the right sized ones.
Intake:
.15mm to .19mm OR .006" to .007"
Exhaust:
.17mm to .21mm OR .007" to .008"
You're better off getting an array of feeler gauges.
The Craftsman one I've got has the following sizes that I use:
.152mm
.178mm
.203mm
.223mm
.258mm
To double-check your tolerances after setting the clearance and tightening the locknut, try to slide the next larger sized feeler in b/w the cam and the rocker arm.
ie: I use .152mm for the intake and double-check with the .178mm feeler to make sure I'm in b/w those two values. I also check with the .203mm gauge sometimes just to see how loose it is if the .178mm is still very loose.
Old Jul 12, 2002 | 09:14 PM
01PYITR's Avatar
are you sure? It seams big to fit
(cause I suck at math)
Old Jul 13, 2002 | 04:31 AM
IN VTEC's Avatar
Don't need any math...just match the numbers and unit of measurement.
Find out whether you're reading that .17 in inches or mm's. If it's in mm, then it's ok. Inches is too big.
Old Jul 13, 2002 | 02:36 PM
Pengo's Avatar
i have a set that folds into this little holder, has a large range of thicknesses and each blade shows in metric and standard.
ok, i guess i didnt really help any. sorry
weaslehunter1
17
Jul 17, 2008 06:15 AM
b16integ
Nov 15, 2006 09:26 PM
spidermancivic
Dec 2, 2005 11:21 PM
fastcrxva
Aug 5, 2005 02:37 PM
Loveless
Apr 17, 2003 05:05 PM
