Good Compression? bent Valve?
Old Mar 11, 2008 | 08:42 PM
sireg6's Avatar
Default Good Compression? bent Valve?
on my sohc im hearing a noise and recently skipped timing a little so i worry i tapped a valve or two but the thing is im holding 180psi at all 4 cylinders and spec is 185psi so is it still possible to have a bent valve and still hold compression? or would it leak right away?
Noobatized
Apr 6, 2014 04:19 PM
89civichb
11
Mar 10, 2009 08:26 AM
Tegraracer90
Aug 6, 2008 09:33 AM
acman1
May 21, 2007 12:06 PM
OBRJosh
Aug 9, 2006 05:25 PM
