Who's installed B16A Hondata IM Gasket?
Old Jul 8, 2002 | 02:58 AM
RagingAngel's Avatar
Default Who's installed B16A Hondata IM Gasket?
I'm a little bit confused about the procedure if I want to block off the coolant flow that runs out of the intake manifold right behind cyl. 4 (next to distributor)
I understand I must T off the fluid flow but what I'm trying to get at is the need to drill the 6holes in my thermostat before I can install this gasket in its "race version" with the coolant block off uncut.
It is listed here in Number 2 from Hondata's DL site
http://www.hondata.com/downloads/gas...stallation.pdf
Has anybody done this before successfully without removing the coolant block off?
Many thanks!
and BTW, I've emailed tech support @ Hondata....just wanted to get some second opinions before they reply to me!
Old Jul 8, 2002 | 07:58 AM
brcivic411's Avatar
Default Re: Who's installed B16A Hondata IM Gasket? (RagingAngel)
http://forums.clubsi.com/showflat.ph...ts&Main=117050
Old Jul 8, 2002 | 08:04 AM
sgT's Avatar
sgT
you do not have to drill the thermostat.
All you have to do it tee the heater line coming from the side of the head
to the port that the other line went to on the thermostat housing.
Old Jul 9, 2002 | 02:08 AM
Default Re: Who's installed B16A Hondata IM Gasket? (brcivic411)
brcivic411. sgT
thanks for the tech support!
it is very much appreciated!
Old Jul 9, 2002 | 08:21 AM
brcivic411's Avatar
np. good luck
Old Jul 9, 2002 | 04:54 PM
BenMara's Avatar
https://honda-tech.com/zerothread?id=132940
Old Jul 10, 2002 | 03:22 AM
WykidEH's Avatar
Default Re: Who's installed B16A Hondata IM Gasket? (BenMara)
What about the idle control vavle?
Old Jul 10, 2002 | 08:40 AM
brcivic411's Avatar
Default Re: Who's installed B16A Hondata IM Gasket? (WykidEG)
you sacrifice that. so if you're in cold climates, expect up & down idle
namewasdallas
Apr 23, 2010 01:27 PM
skata89
Nov 13, 2006 01:21 PM
Jared
Jun 17, 2002 12:01 PM
Jared
Jun 17, 2002 10:48 AM
