LSVTEC cam alignment issues
Old Mar 11, 2008 | 07:11 PM
ToeJam's Avatar
Default LSVTEC cam alignment issues
Every time I set the belt correctly on my LSV it always end up being off half a tooth. I'm using GE adjustable cam gears.
I'm thinking that the difference in block height between the LS and GSR block is throwing it off.
Does anybody know how to compensate for this lost in deck height?
If you know of a quick fix or a walk through regarding this, please speak up.
Thank you.
Old Mar 11, 2008 | 08:29 PM
untuned's Avatar
Default Re: LSVTEC cam alignment issues (ToeJam)
do you have a pic?.
Old Mar 12, 2008 | 12:41 PM
ToeJam's Avatar
Default Re: LSVTEC cam alignment issues (untuned)
anyone?
Old Mar 13, 2008 | 04:30 AM
Mikey3000's Avatar
dial the cams in using the adjustable cam gears. you need a dial indicator setup. if you don't want to go through that, just adjust the cam gears to a good estimate.
Old Mar 13, 2008 | 08:00 AM
ToeJam's Avatar
Default Re: LSVTEC cam alignment issues (Mikey3000)
how would i do that w/out a dial indicator?
Old Mar 13, 2008 | 10:28 AM
Mikey3000's Avatar
you can't
Old Mar 13, 2008 | 12:51 PM
ToeJam's Avatar
I know using a dail indicator is the "right" way to do it but i thought you can also advance the timing one degree for every .011 milled.
heres the deal, Im going to dyno the car right after it breaks in. i just need them to line up good enough for the break in process.
Modified by ToeJam at 2:04 PM 3/13/2008
integlstrike1
Aug 13, 2006 07:45 AM
JerseySiPOS
21
Jan 18, 2006 03:04 PM
JDM00SI
Feb 11, 2005 10:34 AM
dumpeDc2
Nov 17, 2004 09:22 PM
