TRANS PROBLEM S4C B16 TRANS
i just installed a spool in an s4c transmission and now it wont stay in reverse and the transmission get pretty hot when driving for a short time. i took it back appart and i dont see anything obvious. any sugustions?
i would have to say you may have the slider hub for 5/R fipped or the syncro's reversed up top the main shaft. take the case off and show me a GOOD quality picture.. also, there is a chance the slider is not in the correct position on the hub.
i can also fix your transmission for you, if need be.
dividedas1
Oct 3, 2009 11:20 AM
