TRANS PROBLEM S4C B16 TRANS
Old Mar 11, 2008 | 06:49 PM
RaceCarRyne's Avatar
Default TRANS PROBLEM S4C B16 TRANS
i just installed a spool in an s4c transmission and now it wont stay in reverse and the transmission get pretty hot when driving for a short time. i took it back appart and i dont see anything obvious. any sugustions?
Old Mar 12, 2008 | 02:56 AM
DaveF's Avatar
Default Re: TRANS PROBLEM S4C B16 TRANS (RaceCarRyne)
i would have to say you may have the slider hub for 5/R fipped or the syncro's reversed up top the main shaft. take the case off and show me a GOOD quality picture.. also, there is a chance the slider is not in the correct position on the hub.
i can also fix your transmission for you, if need be.
Old Mar 12, 2008 | 07:59 AM
Default Re: TRANS PROBLEM S4C B16 TRANS (DaveF)
would that cause it to get hot also when driving for about 15 min?
Old Mar 12, 2008 | 06:11 PM
DaveF's Avatar
the collar on the main shaft is probably seized on. ive seen it numberous times.
boost ben
Transmission & Drivetrain
Jun 12, 2015 05:16 AM
alex14
Oct 28, 2011 08:37 AM
daymkimchee
Aug 29, 2011 12:04 PM
HitF8
Mid-Atlantic (Sales)
Oct 23, 2009 10:09 AM
dividedas1
Oct 3, 2009 11:20 AM
