Suspension & Brakes Theory, alignment, spring rates....
Ef Front Forks on DC
Old Mar 11, 2008 | 04:47 PM
OC Geezer's Avatar
Default Ef Front Forks on DC
I know there was some info about this a while ago but I can't seem to find it.
I acquired Tein's made for an EF9-R, and plan to put them on my 97 GS-R, I've been informed that the rear will bolt up no problem, but the front might need something switched out?
Any info on this because I need to get this **** on quick.
Old Mar 12, 2008 | 12:41 AM
OC Geezer's Avatar
Default Re: Ef Front Forks on DC (OC Geezer)
Old Mar 12, 2008 | 06:11 AM
eg6ajk's Avatar
Indeed use JDM EF8/9 or 90-3 Integra front forks. Depending on the rear design, possibly ITR or JDM EF/DA/EG LCAs might need to be used!
Old Mar 12, 2008 | 02:48 PM
OC Geezer's Avatar
Default Re: Ef Front Forks on DC (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">Indeed use JDM EF8/9 or 90-3 Integra front forks. Depending on the rear design, possibly ITR or JDM EF/DA/EG LCAs might need to be used!</TD></TR></TABLE>
thanks for the response. is there any way i can use my fronts? what would I need to do to retain my DC front forks?
Old Mar 12, 2008 | 03:55 PM
PIC Performance's Avatar
You would need the front lower mounts designed for your 97 Integra's wider fork.
Old Mar 13, 2008 | 12:02 PM
OC Geezer's Avatar
Default Re: Ef Front Forks on DC (PIC Performance)
jdm4drSi
11
Sep 13, 2008 12:07 PM
Petah
Apr 11, 2006 05:02 PM
hatchlessrex
Jul 12, 2004 03:06 PM
b16crx1
Jun 6, 2004 02:22 PM
ken-e
Sep 4, 2003 03:16 PM
