whats better, mechanical or electronic boost gauge?
Old Jul 8, 2002 | 12:56 AM
CalvitoSol's Avatar
Default whats better, mechanical or electronic boost gauge?
also, can i use electronic boost gauges no matter what type of setup i'm using? i'm asking this because, won't hondata, aem ems, vafc hack, and other management systems fool the ecu from reading boost therefore fooling the gauge too? thanx
Old Jul 8, 2002 | 01:52 AM
TurboR1391's Avatar
Default Re: whats better, mechanical or electronic boost gauge? (theory48)
Correct me if I am wrong, but don't all, if not most boost gauges hook directly into a vaccuum source. If so, I think that makes them mechanical. I am not a gauge guru or anything though.
Old Jul 8, 2002 | 02:49 AM
LsTurbo91's Avatar
Most if not all electronic boost gauges have pressure sensors that come with the unit.
Old Jul 8, 2002 | 02:54 AM
CalvitoSol's Avatar
Default Re: whats better, mechanical or electronic boost gauge? (LsTurbo91)
ic, thanx for your help. i really appreciate it. -Tech ROCKS!!!
Old Jul 8, 2002 | 03:34 AM
MiraiZ's Avatar
electronic is good if you want route the gauge in odd spot (glove box....etc) so that it doesn't create in crimps and give inaccurate readings...otherwise if you know that you can get the vcuum lines to your gauge without causing crimps...mechanical is better...looks cooler!
Old Jul 8, 2002 | 03:44 AM
CalvitoSol's Avatar
Default Re: whats better, mechanical or electronic boost gauge? (MiraiZ)
so unless i HAVE to, i should just stick w/ mechanical and save the cash? thanx
Old Jul 8, 2002 | 03:55 AM
MiraiZ's Avatar
its a matter of taste too...I personally like the look of a mechanical (the way it jumps and jiggles with the engine air flow)...some like like the "never lie" accuracy and smoother flow of the electornic one...but they both do the job...if you are on a budget...getting a mech. one is a good place to save $50~$100
a1320honda
May 27, 2008 03:53 AM
FRernesto
Aug 29, 2007 07:01 AM
