plz help
Old Mar 11, 2008 | 11:19 AM
spoon93's Avatar
Default plz help
a wats up guys i have a 89 dx hatch with a 93 sohc si motor
so the problem is when i go down a big hill the car will cut out almost like it turns off everyone i ask is clueless i had a new fuel pump and filter put in already and still the same so if you have ideas plz let me know asap its my only ride
THANKS H-T
Old Mar 11, 2008 | 01:05 PM
spoon93's Avatar
Default Re: plz help (spoon93)
Old Mar 11, 2008 | 01:12 PM
HONDACIVC93's Avatar
down a big hill and like in nuetral or are you compression braking and it tries to die out?
Old Mar 11, 2008 | 07:09 PM
spoon93's Avatar
Default Re: (HONDACIVC93)
im in gear and i hit the gas and it will just bog i have no throttle responce
Old Mar 12, 2008 | 01:09 PM
z06eateR's Avatar
yea...when on the throttle the car starts to cut out/bog/sputter. give it full throttle and it bogs worse...then all of a sudden, the throttle is back, and the car is drivin normal again....
wtf coud this be1?!?!?!?!? i was thinking fuel pump maybe...but that was replaced along with fuel filter. also...the car is vacuuming when first turned on...then after a few minutes it idles normal...till you rev it up...then once coming back to idle, it will vacuum one or two times...then idle normal...
someone help plez!!! we have been tryin to figure this out forever....
thanks...
Old Mar 12, 2008 | 07:16 PM
spoon93's Avatar
Default Re: plz help (z06eateR)
this is a way better discription thanks zo6eater
Old Mar 13, 2008 | 07:04 PM
spoon93's Avatar
to the top bump
Old Mar 14, 2008 | 07:51 AM
z06eateR's Avatar
Old Mar 17, 2008 | 10:31 AM
z06eateR's Avatar
BUMP
rolledthatho
Feb 20, 2011 05:58 AM
wanderinglost
Sep 26, 2008 05:57 AM
JUN.
Apr 6, 2008 09:31 AM
98TypeSH
Apr 26, 2004 10:25 AM
Rob Dizzle
Feb 27, 2003 05:56 PM
