Horizontal vs cold saw
Old Mar 11, 2008 | 09:30 AM
DTMbimmer's Avatar
Default Horizontal vs cold saw
IF you had to pick one of the two which would you get. Im considering eigther one of these
http://www.vansantent.com/willy_cold_saw.htm
http://www.southern-tool.com/s....html
Old Mar 11, 2008 | 01:42 PM
vtec_lude's Avatar
I think I would definately pick the bandsaw.
Old Mar 11, 2008 | 02:16 PM
ROTARY's Avatar
bandsaw.
Old Mar 11, 2008 | 02:36 PM
paulzy's Avatar
if you don't need to cut anything larger than 2.5" then get the cold saw. I'd rock a cold saw over a band saw any day, unfortunately, cold saws that can cut over 4" OD are money.
Old Mar 11, 2008 | 02:56 PM
CarTunr22's Avatar
It obviously depends on what kind of work you do. If you are making alot of 90* cuts all day then i'd be all over the cold saw. If you are only making a few cuts and do alot of curved of special cuts i'd find a nice old vertical band saw and do that.
I have never really liked horizontal bandsaws for what i do. Although they have their place....
Old Mar 11, 2008 | 08:13 PM
DTMbimmer's Avatar
i cant see myself working with anything more then 2.5"
what would u guys prefure to use when working on header fab
Old Mar 11, 2008 | 09:24 PM
CRMB's Avatar
OG Fabricator
Default Re: (DTMbimmer)
Cold saw, but not that cold saw.
Old Mar 12, 2008 | 10:50 AM
mulisharider11x's Avatar
Default Re: (CRMB)
hey CRMB what cold saw do u use... i have one simular to this exept a lil more beafy and my work is looking to upgrade....
Old Mar 12, 2008 | 11:03 AM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTMbimmer &raquo;</TD></TR><TR><TD CLASS="quote">i cant see myself working with anything more then 2.5"
what would u guys prefure to use when working on header fab</TD></TR></TABLE>
the cold saw would be tit's then
Old Mar 12, 2008 | 02:05 PM
CRMB's Avatar
OG Fabricator
Default Re: (mulisharider11x)
For fab shop, we run scotchman cpo 350 ltvs saws (low turn, variable speed). They are about $6k a piece with the variable speed and flood, but worth every penny. Extremely reliable saws, and we beat the crap out of them. One of these was actually the first saw I ever bought. http://www.scotchman.com/specs.php?index=25
For our production tube cutting line, we run an Adige TS71 CNC automatic cold saw with automatic brush deburring line. Its no longer the current model (1998 vintage), but the current model can be seen @ http://www.blmgroup.com/TS72-C....html
The TS72 is around $1M. I'm not sure what a TS71 ran but I'm sure it was similiar considering what we payed for it used. This replaced our older scotchman cpo 315 rfa.
We also run Everett production hot saws for production trimming stainless parts, and a 19x19 do-all production automatic band saw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mulisharider11x &raquo;</TD></TR><TR><TD CLASS="quote">hey CRMB what cold saw do u use... i h
Old Mar 13, 2008 | 09:38 AM
DTMbimmer's Avatar
Default Re: (CRMB)
what do you think of this one, im trying t keep the budget under 2k
After looking at the space i have, it looks the like a cold saw is the only way to go space wise, otherwise with the bandsaw id have to put it in a different location
Old Mar 13, 2008 | 06:02 PM
CRMB's Avatar
OG Fabricator
The vise on that one sucks, you want a double self centering vise for fab work. I would spend about another k and buy a scotchman used off ebay. There are some good deals to be had if you are patient. Parts break on these things with extended use, supporting/maintaining it should be part of the cost equation. Having owned a lot of different saws both domestic and import, I really hate messing with imports unless you have to (in the event the technology is just too superior like adige (italy) vs scotchman (usa)). There is nothing like waiting 2-3 weeks with a down saw for a couple parts out of europe or asia.
Old Mar 14, 2008 | 10:29 AM
DTMbimmer's Avatar
Default Re: (CRMB)
Good point. I would still rather buy something new.
what if i where to go and modify the vice to accept two of these
http://www.grainger.com/Grainger/items/6X381
and then make it so that the vice would be self centering
Masho
Honda Civic (2001 - 2005)
Jan 30, 2012 12:09 PM
EGIan
52
Feb 13, 2009 08:08 AM
soloteg
Apr 4, 2003 08:28 AM
fiebru1119
Apr 18, 2002 08:13 PM
