What to remove in a G3 Integra to get it down to 2,300 LBS?
Old Jul 7, 2002 | 10:09 PM
Ri5e's Avatar
Default What to remove in a G3 Integra to get it down to 2,300 LBS?
Please list all the things I can remove to get it down to 2,300 LBS. I noticed that C speed got their Integra down to 2,300 LBS and the interior looks like its pretty much all intact??
And also what I can get to lighten up the car. Such as racing seats, etc?\
Thanks.
Old Jul 7, 2002 | 10:55 PM
Mr. Softee's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (BG Boost)
ask mike k
Old Jul 7, 2002 | 11:04 PM
redteg1's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (94goldjungsr)
go anorexic..
Old Jul 8, 2002 | 06:46 AM
The Rob's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (redteg1)
I dont know what my car weighs. I have a 93ls (gen2) with no interior paneling, no spare tire, no jack, no sound deadening, no firewall, gsr wheels, gonna have sparco front seats, no back seat, no rear seatbelts, no carpet, no rear speakers, no power steering, no rear wiper assembly, no headliner, etc. I'll let you know what mine weighs whenever I get to the track and get to drive it on the scale. I think I still weigh in at about 2400-2500. Maybe even more. Who knows.
Old Jul 8, 2002 | 06:51 AM
The Rob's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (Zero_Effect)
O and I have JDM 1 piece headlights which weigh a lot less then stock USDM (Plastic housing vs. metal) and plan on gettin some rota slipstreams and a CF hood for weight reduction too in addition to the sparco seats.
Old Jul 8, 2002 | 09:15 AM
Tweakmeister's Avatar
I don't know what C-Speed did...
but the easiest way is to remove all accessories like A/C, ABS, etc....and then start cutting into the non-essential body metal. Replace it with fibreglass or something.
Old Jul 8, 2002 | 10:09 AM
JDMCRVTEC's Avatar
evrtything you don't need just take out, ac, carpet seats, spare tire, jack, power steering, door panels rear panels, etc etc,
Old Jul 8, 2002 | 11:47 AM
ocbeta's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (JDMCRVTEC)
then you have a loud car.
Old Jul 8, 2002 | 12:00 PM
bulldog_RS20's Avatar
AC fan, power steering, heater core/fan assy, sunroof, rear wiper, fender liners, front and rear latches...
My G2 full race prepped, w/o driver or gas = 2990 lbs.
I hope this is a track-only car...
Old Jul 8, 2002 | 01:05 PM
owen_the_soyboy's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (bulldog_RS20)
all of the accessories, power everything, abs, airbags, bumper supports, swaybars, swap over civic small brakes, remove radio and antenna motor, replace moonroof and motor with just a fibergalss or aluminum insert. install a momo steering wheel and hub, remove all carpeting/mats/sound-deadening-tar.
lightweight header and catback, use a testpipe.
super light wheels (13" vx if you use vx brakes)
racing seats will also help ... my sparco ultras weight half of stock, bolt them to the floor to save weight of sliders/brackets.
remove all but the necessary seatbelts.
remove spare tire, jack and all misc parts.
hmm, also go on a diet.
Old Jul 8, 2002 | 01:12 PM
brinks's Avatar
What kind of g2 teg weight 2990 lbs? Sounds way above even stock weight to me.
Old Jul 8, 2002 | 01:21 PM
2fastGSR's Avatar
King of the One Liners
2990???? Are you sure that isn't a CRV????????
Old Jul 8, 2002 | 02:01 PM
Austin's Avatar
This is from Mike K...read the rest here
Just figured it would be a good idea to start a thread listing items for weight reduction. People constantly email me asking how I got my Integra down to 2320 lbs., plus I figure this would be good for future search reference, etc.
If anyone has anything to add, feel free...
Here's your answers Jay...
*front bumper support
*rear bumper support
*ABS system
*switched PS rack to manual Civic CX unit
*ditch OE manifold and cat for a 4-1 w/ test pipe
*remove sound deadening(GSR/LS only)
*remove rear wiper and motor
*shave antenna and remove antenna motor
*driver and pass. air bags
*SRS harnesses and SRS control module
*apexi' WS suspension (total 12lbs. lighter than stock altogether)
*aluminum flywheel(much lighter than stock)
*remove passenger side dash brace(thick *** bar behin dash)
*lightweight rotors
*leightweight wheels
*AEM (lighter than OE intake system)
*remove strut tower bar and rear upper and lower body braces, also considering sway bars.. but this was DRASTICALLY hurt the car's handling and performance
*switch out power door lock actuators for Integra RS units
*spare tire and jack(DUH)
*evap and emissions system and canister (not applicable to all. there is no emissions or inspection here, so I do it.)
*brake dust shields
*exhaust tunnel heat shield
that's about all i can think of right now. you can also pull the radio, heater, A/C, etc.. but that's all creature comforts.
_______
Mike K.
Old Jul 8, 2002 | 06:48 PM
The Rob's Avatar
You have to mean 1990lbs without driver and gas. Also, what class SCCA could you race in that stripped out, what kinda engine did you have, and how competitive were you? Also, do you have any vids?
Old Jul 8, 2002 | 07:43 PM
LillDragun's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (Austin)
Mike K.
does this mean the GS and RS don't have the sound deadening stuff or jsut the RS
Old Jul 8, 2002 | 09:53 PM
Volcom's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (LillDragun)
Nope, RS LS GS all have sound deading. ITR doesn't.
Old Jul 9, 2002 | 11:40 PM
ElephantSuprise's Avatar
pull the motor and suspension, ought to do the job
Old Jul 10, 2002 | 09:02 AM
G2Integrity's Avatar
Default Re: What to remove in a G3 Integra to get it down to 2,300 LBS? (ElephantSuprise)
I weigh in at around 2,450 and I started out with a stock 2,628 pound GS. I have i/h/e (all lighter than stock), removed rear tow hooks, removed floor mats, removed EVERYTHING behind the front seats. I also might take out the AC and get some Corbeau Forza racing seats which are really light.
Clutch502
Dec 14, 2005 07:29 PM
Todd00
Mar 21, 2005 04:07 PM
Integacivic
Jul 19, 2004 11:44 AM
Westrock2000
Nov 11, 2001 10:52 PM
itr501
Oct 17, 2001 01:18 PM
