Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
new flywheel. check my pilot bearing
Old Mar 10, 2008 | 11:43 PM
JDMInspired's Avatar
Default new flywheel. check my pilot bearing
i ordered a new exedy oem replacement clutch and flywheel from gripforce and there's a pilot bearing already pressed in the flywheel. question is, should i tap the bearing more in so it will sit flush or is this how it should be sitting?
Old Mar 11, 2008 | 09:23 AM
moores55's Avatar
Default Re: new flywheel. check my pilot bearing (JDMInspired)
The inside has a lip that it seats on so you can only tap it so far in. Looks like it's good or just about.
Old Mar 11, 2008 | 10:46 AM
Default Re: new flywheel. check my pilot bearing (moores55)
hmm alright. anyone else?
Old Mar 11, 2008 | 11:33 AM
djmota's Avatar
it should be tapped in all the way to the lip on the flywheel
Old Mar 11, 2008 | 12:05 PM
moores55's Avatar
well try this, beat the **** out of it and if it wont go any farther in then it's good.
redman223
Feb 15, 2011 08:34 PM
Nathan007
Transmission & Drivetrain
Jun 19, 2009 06:31 PM
skunkwhat
May 15, 2005 09:04 PM
JAYGSR
Oct 5, 2004 05:56 PM
RACESMART
May 7, 2004 09:24 PM
