gsr swap del sol a/c bracket d-series compressor which belt?
ive got a gsr swap in a ek with a del sol bracket stock d-series compressor i had a oem gsr belt but it was too small will the dohc del sol belt work? or which does?
no i used a gsr tensioner pulley on the del sol a/c bracket i bought a oem gsr a/c belt thinking it would fit since its a gsr motor but the gsr a/c belt is too short
u can try del sol vtec ac belt. i know it is pretty long. my ac setup is kind of weird and unique. i bent a few ac pipe to make it fit into gsr compressor by using jdm b16a ac bracket,
atleast crazyguy tried!
ok, being that you have the d-series compressor on the p54 bracket, you can go ahead and use the civic compressor belt as well. nothing changes except the bracket pulley and tensioner.
LXguy
Feb 6, 2002 12:00 PM
ac, air, belt, bracket, compressor, conditioner, del, dseries, ek, gsr, pulley, replacement, sol, swap, tensioners
