h23 help ASAP!!
What is the most you can have a sleeved h23 bored, and what would that make the engine... i know a guy who has a h22 bored to almost a 2.4 ltr, what is the largest bore i can go if i plan to run a lot of boost, and what would that make my enigne????
thanks for the help guys
I don't think I've ever seen a H block sleeved larger than 89mm. 90mm might be ok for NA, but there would be no room for error if a problem should arise down the road.
i was told the guy down here with his h22 bored to a 2.4 had about 125grand in his motor, he's pushin 780+ horses before nitrous and over 1000 with. i'm just trying to get an idea of what would be the best setup, i'm trying to push at least 600 hp once i put my turbo setup on
