Rear Quarter Rust
I'm just wondering if anyone has used a kit similar to these with any success...
http://fixmyrust.com/
Replacing the rear quarter panels is frikin expensive -- just the panels alone are expensive as hell new. Then the work that goes into replacing them is hefty, definitely out of the scope of what I have the time/equipment to do at this point. I know that replacing them is the best option but my wallet and I just want to see what alternatives are out there.
How bad is the rust take pics cuz u might not need to buy a quarter if you can fix it as is i cut the rust off my quarter plan to get some mesh and filler it in like it was never there
That actually doesn't look too bad. Patch panels would probably be alright. have you pulled your interior and checked the backside yet? Also, how do your rockers look?
I do not recommend the mesh, fiberglass, and body filler route. If you don't plan on holding onto the car for a long time then by all means go for it (with an experienced bodyman it can look great). However, I personally wouldn't be able to live with knowing what was under the paint/behind the interior panels (regardless of how long I decided to keep the car for)
. Just my 2 cents.
Best of luck on your choice
. Just my 2 cents. Best of luck on your choice
okay since im in collision repair this is like a walk in the park for me. as stated b4 remove your rear interior and verify if the rust has penetreted beyond the surface, if not this will be easier for you not to worry. you can sand down the rust. i recomend feathering out the paint. just in case ur not sure feathering means when u sand down each layer of paint u want them to be rings around eachother. from bare metal in the center where the rust is at to the clear coat. its like the paint layers are stretched and pulled back like stairs each layer is a step. after that u can take it to a body man and he could straighten the metal fill any rust holes and repaint the area. the term is called "Spot and Blend". if u need more info PM me
mine rusted all the way threw so i cut it out taped up cardbard behind what i cut out and put the bondo over the cardboard sand and repeat till it looks like how the car came prime but put a little extra prime were the rust usto be sand and paint
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex89 »</TD></TR><TR><TD CLASS="quote">mine rusted all the way threw so i cut it out taped up cardbard behind what i cut out and put the bondo over the cardboard sand and repeat till it looks like how the car came prime but put a little extra prime were the rust usto be sand and paint </TD></TR></TABLE>
So this is pretty much what NOT to do...
card board and bondo? u might as well scrap the rex. look find ur self 20 guage sheet metal fairl cheap for a square foot. cut out what u cut and have an experienced welder weld it up for u. grind down the welds and then u cap use a GLAZING PUTTY for minor inperfections. that bondo u used will and i mean will fail with in a year or less. do it right the first time. oh and for the steel automotive grde is preferable but if u cant regular metal will do fine
You call that rust!? Wish I had a pick of mine.
Buy the patch panels and cut them to what you need, don't use the entire piece. Thats what im doing so i dont have to bother with shaping the flares or anything.
KevinEF7
Paint and Body
Jul 22, 2013 02:25 PM
hondapimp125
May 29, 2008 07:03 PM
Crimson_Tide
Jul 1, 2005 09:27 AM
