Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 Si- Car misfires in turns at low rpm???
Old Mar 10, 2008 | 05:55 PM
Falcameno's Avatar
Default 08 Si- Car misfires in turns at low rpm???
Engine seems to "misfire" at 1500-2300 rpm 2nd or 3rd gear under 30mph. Anybody run into that problem? 2008 Civic Si K20z3 w/ 200 miles.
Old Mar 10, 2008 | 06:00 PM
Michael Bolton's Avatar
Default Re: 08 Si- Car misfires in turns at low rpm??? (Falcameno)
Never heard of that happening. Car that new should be brought back to the dealer stat.
Is it happening when the car is cold, any more details?
Old Mar 10, 2008 | 06:12 PM
Falcameno's Avatar
Default Re: 08 Si- Car misfires in turns at low rpm??? (Michael Bolton)
I have not noticed anything when the car is cold mainly warm. Its going back to the dealer tomorrow. I'm a tech myself and just the symptom is boggeling my mind.
Old Mar 11, 2008 | 03:49 AM
IT GUY's Avatar
what exactly do you mean by "misfire"?
Is it just getting jerky in gear @ 1k-2k rpm or can you actually hear a misfire?
Old Mar 11, 2008 | 05:56 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falcameno &raquo;</TD></TR><TR><TD CLASS="quote">Engine seems to "misfire" at 1500-2300 rpm 2nd or 3rd gear under 30mph. Anybody run into that problem? 2008 Civic Si K20z3 w/ 200 miles.</TD></TR></TABLE>
There is your problem.
Old Mar 11, 2008 | 06:50 AM
hiwastar's Avatar
Default Re: 08 Si- Car misfires in turns at low rpm??? (Ed 341)
I just got a 08 Si and have no problems, but I also dont run around town at such a low RPM. 3rd gear at 30 mph is fine for me but not if I need to accelerate at all....Is this your first honda because they dont make any torque down low so you may just be experiencing that? Try getting it higher in the RPM band before upshifting. If it truly is a misfire situation, get it back to the dealer and make them fix it.
Old Mar 11, 2008 | 01:37 PM
ChargedSI's Avatar
It sounds like maybe a vacuum line came loose or came off. Vacuum shouldis high at lower RPM (20 inches at idle). Have you checked to see if any vacuum lines are loose or cut?
Old Mar 11, 2008 | 03:30 PM
i-VTEC_DOHC's Avatar
sounds like a loose or disconnected vacuum line to me. this happened in the ep i used to have and it misfired at low rpm and had the fluctuating idle
Old Mar 11, 2008 | 07:28 PM
Falcameno's Avatar
Default Re: 08 Si- Car misfires in turns at low rpm??? (hiwastar)
Yea, this is actually what seems to be some sort of misfire, only when taking a slow 90 degree turn. And it always does it coming out of the turn right when you get back on the gas.
Old Mar 12, 2008 | 03:44 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falcameno &raquo;</TD></TR><TR><TD CLASS="quote">Yea, this is actually what seems to be some sort of misfire, only when taking a slow 90 degree turn. And it always does it coming out of the turn right when you get back on the gas.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">what exactly do you mean by "misfire"?
describe the misfire.
Old Mar 12, 2008 | 08:03 AM
Civic92Turbo's Avatar
Default Re: 08 Si- Car misfires in turns at low rpm??? (IT GUY)
my mugen does the same thing but I shift at 3500 rpm and it blogs/backfires it seems to happen a lot in 3rd gear. I have about 2500 miles now. but from what I have seen it only happen on cold starts. warm up the car then see what happens...
Old Mar 12, 2008 | 08:08 AM
IT GUY's Avatar
Default Re: 08 Si- Car misfires in turns at low rpm??? (Civic92Turbo)
do you guys know what a misfire is?
neither civic92turbo or the OP have described symptoms of a misfire.
Old Mar 12, 2008 | 09:33 AM
REMS08SI's Avatar
I notice some hesitation from my 08 when its cold and it hasn't completely warmed up before i start driving it, but never a misfire situation..my 02 GTI 1.8t would misfire when i had a coil pack going bad..so that could be another key to your problem. Keep us posted on what you find out
Old Mar 12, 2008 | 01:48 PM
high_revs's Avatar
i bet its just the hesitation from the drive by wire...you prob came from a cable throttle body car previously and now it feels totally different...the hesitation is normal, sucks but normal.
Old Mar 12, 2008 | 03:17 PM
Well sorry, mine just blogs alot and has poping sounds where the motor has to much fuel in the 3500 rpm range. but it may just be what High_Rev stated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">do you guys know what a misfire is?
neither civic92turbo or the OP have described symptoms of a misfire.</TD></TR></TABLE>
Old Mar 12, 2008 | 07:36 PM
24boosted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 &raquo;</TD></TR><TR><TD CLASS="quote">
There is your problem.</TD></TR></TABLE>
+1
Old Mar 12, 2008 | 08:52 PM
Falcameno's Avatar
this does it fully warmed up though
jdmshawn95
26
Nov 2, 2010 10:27 AM
ohkx7
14
Oct 31, 2007 06:47 AM
Black_K20
10
Oct 17, 2006 02:32 PM
Hellzcivic
21
Aug 23, 2006 02:36 PM
reditr
Sep 14, 2004 11:15 PM
