Help with drive axle
Old Mar 10, 2008 | 03:52 PM
jfiguer's Avatar
Default Help with drive axle
I m installing a new axle on my civic 96 passenger side but i have problem puting the axle in the transmision it dont want to go all the way in PLEASE I NEED some help
Old Mar 10, 2008 | 04:34 PM
Kista20's Avatar
Default Re: Help with drive axle (jfiguer)
what I did was I couldn't just push it in there so I turned around and put my feet against the wheel hub and used my legs as leverage to help me push it in and finally it popped right in, I didn't have to do that on the drivers side because it went right in.
Old Mar 10, 2008 | 06:29 PM
jfiguer's Avatar
Default Re: Help with drive axle (Kista20)
thanks for that quick answer. the only thing that im not sure is the spline of the axle they should match when you push it by hand or you have to rotated
Old Mar 10, 2008 | 06:52 PM
Kista20's Avatar
you have to line the splines up so they will mesh together so to speak then just force it straight in. My passenger side popped when it went in but the driver side I couldn't really feel it pop in but I kept pushing as hard as I could and it wouldn't go in anymore so I felt pretty sure that I had it in there.
Old Mar 11, 2008 | 11:16 AM
blk92_d16's Avatar
Yep, using the hub kinda pound it in the rest of the way.
HondaCivic666
Jun 5, 2018 10:25 PM
tylerp318
Oct 26, 2014 08:36 AM
jdm96gsr
Nov 21, 2010 08:24 PM
rhdekhatchie
Mar 16, 2008 10:17 PM
ill phil
May 15, 2003 06:27 PM
