h22 crx with a virgin p13 dyno, the shop told me is running too lean what do you guys think
Old Mar 10, 2008 | 03:42 PM
hondastudent1on1's Avatar
Default h22 crx with a virgin p13 dyno, the shop told me is running too lean what do you guys think
The guy made one run and said the motor is running lean. IMG]http://i252.photobucket.com/albums/hh25/kwasi_04/DynoFS.jpg[/IMG]
Default Re: h22 crx with a virgin p13 dyno, the shop told me is running too lean what do you guys think (hon
Old Mar 10, 2008 | 03:51 PM
Crx Jimmy's Avatar
if its a stock motor that looks like it would be fine, if you have an adjustable fpr you can try adding just a couple pounds or pressure and see what it does. just curious why would you dyno and check o2 on a stock motor with a stock ecu? Is it acting funny?
Old Mar 10, 2008 | 05:15 PM
I wanted to see what it did before I started tunning with the p28
Old May 20, 2008 | 10:23 PM
andre4444's Avatar
hey i have stock p13 and i was having a 15.5 AFR ... teacher said it was fine
Old May 21, 2008 | 06:30 AM
mr. Grind's Avatar
i don't think your afr is completely safe. 1 tank of bad gas and there could be problems. By the way whats you tq reading on that run.
xh22xcrx
Southwest
Nov 17, 2012 10:08 PM
bassfreq
14
Mar 25, 2010 03:07 PM
hondastudent1on1
Mar 10, 2008 07:05 PM
squarepusher
27
Dec 15, 2006 01:36 AM
blackoutcivic
May 14, 2005 08:19 PM
