k20a3 head questions? did a search and found nothing!
Old Mar 10, 2008 | 03:08 PM
CR-V-tech's Avatar
Default k20a3 head questions? did a search and found nothing!
ok guys, I have a k20a3 and was wondering if you can upgrade the valvetrain on the a3 head to that of the a2 or another true dohc vtec k-series head, I was told that the castings are the same and you just need to replace the rockers and cam on the exhaust side, all the oil passages are the same! I'm trying to find out if this true or not? If so I would like to upgrade this motor to the type s cams, and throw in some better springs, etc. I would greatly appreciate any info, thanks alot!
Old Mar 10, 2008 | 03:18 PM
mymomsdrunk's Avatar
Default Re: k20a3 head questions? did a search and found nothing! (CR-V-tech)
or you could just buy aftermarket cams for the a3, they would be around the same price as the oem ones
Old Mar 10, 2008 | 03:30 PM
CR-V-tech's Avatar
Default Re: k20a3 head questions? did a search and found nothing! (mymomsdrunk)
yea no doubt man thanks for the reply, but does anyone know if the rockers are swap-able?
Old Mar 10, 2008 | 03:44 PM
FourBangerIndustries's Avatar
yes you can put the type s rockers into the a3 head. just to a search, i believe jeremy @ inline pro did the write up.you have to switch the pins in the rockers around because the a3 head doesn't have the lost motion assembly. and im not sure where you got the info from, but i doubt that the a3 flows as much as the a2 head. you'd also need a kpro to do that swap. so before you do anything, you should add it up and see if its worth the money. hope that helps
Old Mar 10, 2008 | 05:56 PM
CR-V-tech's Avatar
Default Re: k20a3 head questions? did a search and found nothing! (FourBangerIndustries)
thanks alot man!
Old Mar 10, 2008 | 07:49 PM
no prob. good luck with that.
Old Mar 10, 2008 | 08:07 PM
risktypeS's Avatar
it'll cost a pretty penny and the A3 head does not flow as well as the A2 head. When it comes down to it, you'd be better off just buying an A2 and going from there.
Old Mar 11, 2008 | 05:27 AM
blueshark123's Avatar
Default Re: k20a3 head questions? did a search and found nothing! (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">it'll cost a pretty penny and the A3 head does not flow as well as the A2 head. When it comes down to it, you'd be better off just buying an A2 and going from there. </TD></TR></TABLE>
Yeah Im with him. All you are essentially doing is putting a types cam into the a3 head which is not worth the work when an aftermarket a3 cam is readily available.
Old Mar 19, 2008 | 06:06 PM
CR-V-tech's Avatar
Default Re: k20a3 head questions? did a search and found nothing! (blueshark123)
i understand that, but i want it to be a true dohc vtec! and if it doesn't flow as well i can just have it ported! thanks for the info!
u_tal
Dec 31, 2009 11:23 AM
bigsnorlax
Apr 28, 2009 11:00 AM
aust 97 coupe
14
Jan 7, 2009 03:36 PM
v!taminb16
13
Feb 15, 2008 07:01 PM
