h22 civic problem
Well i was driving no problems stopped at a carwash and when it was time to leave....put the key in the ignition and no fuel pump turned on....it was just cranking but motor would not turn on.....i made sure the fuel pump works...i direct connected it to a battery and it works perfectly...so i cranked while the fuel pump was connected and still no turn on...im guessing there isnt any spark.....i checked the main relay and it clicks when i turn the ignition....i tried another ecu and still does the same....checked the plugs to the harness and they are all connected and check the fuses....can someone help me out!!!
potatostix
10
Jun 17, 2023 10:27 PM
Pr0j3cT95dX
10
Dec 6, 2010 09:34 AM
ThatRHDstatus
Aug 8, 2010 08:05 AM
deckster333
Sep 10, 2006 10:43 AM
