Suspension & Brakes Theory, alignment, spring rates....
i have a problem w/ my rotar i think
Old Mar 10, 2008 | 12:45 PM
homer_eps's Avatar
Default i have a problem w/ my rotar i think
i got in a wreck last year with my ek hatch and i left the car for a while until i had the money to repair it well
my homeboy gilbert is getting it done but we have a problem with my left wheel is wobbily im thinking the rotor is loose but he said that the nut for the axle is tight and it stil does the same thing does any body know what can i do ???
Old Mar 10, 2008 | 12:59 PM
homer_eps's Avatar
Default Re: i have a problem w/ my rotar i think (homer_eps)
Old Mar 10, 2008 | 08:46 PM
TotalBalance's Avatar
first off, there are two screws that is holding the rotor in place to the hub, not the axle nut. So tightening the axle nut wont do anything to the rotor.
Tire wobbling has many reasons.
rims may be bent, alignment may be off, LCA/UCA or knuckle or anything can be bent and causing this vibration.
just check if anything is out of order/bent/ etc etc.
btw balance your wheels, that can cause wobbling too
itr1244
Apr 14, 2008 12:25 PM
K-Spec
Oct 21, 2006 08:41 AM
GarageAlchemist
Jul 27, 2006 03:04 PM
tuan...
Aug 27, 2004 05:03 PM
SikofFalln
Sep 4, 2002 11:38 AM
