Strange squeaking noise from engine.
Old Mar 10, 2008 | 12:36 PM
cuteboi's Avatar
Default Strange squeaking noise from engine.
I sort of finished the engine rebuild of a D15B1, I'm getting a squeaking sound from the pulley area, what can I do to reduce it, or just eliminate it.
If it's the alternator, what can I use to lube it up, so it doesn't squeak, if it's my timing belt tensioner, what do I use on that too...
I am not sure where to go from here, once I reduce the squeaking, I can tackle the other problems the engine is having, need to learn with the shitty/cheap engine before I try a B or better D series engine.
Once I master this, believe me, there will be a swap. Just so you guys don't suggest for me to just get over the problems and do a swap... (I hate those type of guys that suggest that as a fix for everything)
Yes I did use the search function, got more hits about suspension, and brakes.
EDIT: This is all just sitting there in neutral, and this is a 5speed, and no AC/PS, just alternator on the acc wheel.
Old Mar 10, 2008 | 01:42 PM
Former User's Avatar
Default Re: Strange squeaking noise from engine. (cuteboi)
Check whether the alternator belt is loose and slipping. If so, tighten up the belt tension.
Old Mar 10, 2008 | 02:15 PM
cuteboi's Avatar
I did check the tension on both the timing and the alternator, I should have stated that too, but I don't know how tight it should be, it doesn't flex at all, and the squeaking is getting worse now, and the timing belt isn't slipping I haven't installed the timing belt covers yet cause I may have to redo the head again, cause I forgot to get the valve seats relapped.
Old Mar 10, 2008 | 02:17 PM
Default Re: (cuteboi)
Check whether a bearing in the alternator or water pump is bad.
Old Mar 10, 2008 | 02:20 PM
cuteboi's Avatar
Hmm, didn't see in the Chilton manual on how to do that, could you shed some light on how I check the bearings, and what I could do to test it out?
Old Mar 10, 2008 | 02:30 PM
Alternator: Take off belt and check whether the pulley spins freely, quietly, and has no freeplay.
Water pump: Take off timing belt and check whether the water pump pulley spins freely, quietly, and has no freeplay.
Old Mar 10, 2008 | 04:19 PM
cuteboi's Avatar
Default Re: (RonJ@HT)
ok, I redid the torque run on the alternator that fixed the squeaking noise.
Thanks.
eaglesclaw121
Apr 11, 2011 01:08 PM
JaeEK
15
Apr 21, 2008 06:36 PM
onnoff7
Jan 25, 2006 12:50 PM
devilpuppy
Sep 10, 2005 07:38 AM
hobo79
Feb 22, 2002 03:40 PM
