P73 ECU Pin out w/ Link... verification needed
Hey guys,
I'm doing a B18C5 (97 spec) swap with a P73 ECU and need to add a knock sensor to my USDM Harness.
I pulled my original 96 SOHC D16Y5 w/ P72N ECU(V-tech-E), out and am using the harness that went on it instesd of the JDM harness that came with the B18 motor, but now I need to add the knock sensor to the harness and need to verify the pin out. I did some searching through the FAQ's and found a link to another site and I think...I have the correct pin out. Can one of you guys check it out and confirm that this is the right pin out for to use on my P73 with my USDM Harness.
http://technet.ff-squad.com/wiring.obd2a.htm
that is correct.
Just to make sure, check this thread to make sure you have the right ECU... https://honda-tech.com/zerothread?id=2067011
j_scobar
Mar 6, 2008 10:56 AM
