Bad gas mileage..help..need ideas.
Old Mar 10, 2008 | 07:05 AM
mortificationrock's Avatar
Default Bad gas mileage..help..need ideas.
Well I currently drive a 98 EJ8 with about 146,000 miles. Recently honda did a tune up with wires rotor etc. So that's all covered. Recently im getting 20mpg. I mean wtf? Is that normal? What else can I check for. And that's my best mileage driving like a granny. I really need some help guys, please help out. I already tried injectpr cleaner but didn't work. Also I just recently did SMOG on it and I had high HC if that helps.
Old Mar 10, 2008 | 07:11 AM
rpared01's Avatar
dam, for sohc that is bad. you should at least be getting 25 mpg or more. is it all stock ?
Old Mar 10, 2008 | 07:16 AM
Default Re: (rpared01)
Well that's what I tought. And yes car is stock except for a intake I just put on. But even before I installed the intake it was the same. Seems like I need help bad then...huh.
Old Mar 10, 2008 | 07:27 AM
rpared01's Avatar
have you had the injectors clean ? how long ago did they do the tune up ? check your tire presure too
Old Mar 10, 2008 | 07:38 AM
Well the tune up was done about 1,000 miles ago along with the oil change they also did. As for fuel injectors being cleaned well I didn't know that was possible. What does a bad PCV valve affect? Im just throwing out ideas. Tire pressure is good. Believe me I have tought of the little things already. I don't want to start dumping money all crazy and **** that's why im asking what can be wrong. I mean like I mentioned I had high HC in my recent smog check. I mean I passed at max. Meaning 1 more digit and would've failed the test. Any other ideas?
Old Mar 10, 2008 | 07:44 AM
rpared01's Avatar
ok, idea's. have you done a compression test on the motor ?
xxvinxx43
18
May 17, 2011 03:08 PM
integ_lude
Jan 2, 2008 11:04 AM
alexisthemovie
Dec 20, 2006 08:24 PM
mikehawkBUiLT
34
Nov 1, 2004 05:17 PM
Alawot
Jul 6, 2004 11:00 AM
