will struts from a eg fit a 00 civic coupe?
Old Mar 10, 2008 | 02:21 AM
jr000's Avatar
Default will struts from a eg fit a 00 civic coupe?
sums it up/\...thanks guys
Old Mar 10, 2008 | 01:49 PM
jr000's Avatar
Default Re: will struts from a eg fit a 00 civic coupe? (jr000)
anybody know?
Old Mar 10, 2008 | 01:51 PM
97Ej6mike's Avatar
yes.
I have 92-95 setup on my 97 civic.
Installed it without any problems.
Old Mar 10, 2008 | 04:37 PM
jr000's Avatar
Default Re: (97Ej6mike)
alright thanks....
Old Mar 10, 2008 | 05:10 PM
vsmhatched's Avatar
no...
92-95 civic and 94-01 integras except Type R's share the same suspension
96-00 civics share the same.
looking into buying full coilover sets, like tein, mugen, d2, function&form...they dont sell them for 92-00 civics as one, they sell 92-95 and 96-00 for civics, i believe they are different
Old Mar 10, 2008 | 05:41 PM
jdmztrane's Avatar
Default Re: (vsmhatched)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsmhatched &raquo;</TD></TR><TR><TD CLASS="quote">no...
That is not 100% true. You can install EG suspension on an EK, EM1, or EJ chassis. You just cant put EK suspension on to an EG chassis. The front struts fit fine. The rears you will need spacers for because the fork at the bottom of the strut is wider on the EG struts than the EK. Trust me, I put Function Form Type 2's on my car that came off a 92-95 Coupe and I drive a 98 Coupe. It will work fine.
Easiest way to get the correct spacing is to buy some washers that fit over your LCA bolts and put an equal amount on each side. Some companies offer the spacers at the exact length, but they charge more than the 80 cents that I bought my washers for.
Old Mar 10, 2008 | 06:00 PM
vsmhatched's Avatar
Default Re: (jdmztrane)
my fault....i just knew 96-00 wouldnt fit on 92-95, didnt know it could work the other way around, just figured it wouldnt. Thanks for clearing that up tho
Old Mar 10, 2008 | 06:46 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsmhatched &raquo;</TD></TR><TR><TD CLASS="quote">my fault....i just knew 96-00 wouldnt fit on 92-95, didnt know it could work the other way around, just figured it wouldnt. Thanks for clearing that up tho </TD></TR></TABLE>
Yea , i was about to say, it works from EG to EK, not the other way around.
Kyo Babic
10
Jul 8, 2015 06:03 PM
buddhax215
Feb 14, 2007 10:31 AM
B16B_coupe
Suspension & Brakes
Aug 22, 2006 04:33 PM
MarkZeroNine
Nov 2, 2003 08:24 AM
