Kaaz LSD Oil Options
Old Mar 9, 2008 | 11:22 PM
Paul-eg's Avatar
Default Kaaz LSD Oil Options
hey,
I have a kaaz lsd in a b16 trans. My outputshaft is leaking so im replacing the seals and while doing that i was going to change my fluid. Not sure what to put in it. Amsoil MTF with the ams friction modifier or Amsoil SAE 80W-90 Synthetic Gear Lube, GL-5, MT-1 with friction modifer? Or will those not work at all?
Thanks
Paul
Old Mar 10, 2008 | 12:53 PM
Paul-eg's Avatar
Default Re: Kaaz LSD Oil Options (Paul-eg)
Also noticed this on the ams oil website which might be good
Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG)
Thanks
Old Mar 10, 2008 | 10:37 PM
Paul-eg's Avatar
ttt
Old Mar 28, 2008 | 11:33 PM
Paul-eg's Avatar
Well i had a leaky output shaft seal fixed that and changed to redline MTL with Frictionmidifer. Everything feels great shifts smoother except at low speends I get a loud sqeal since I changed it??? When i turn right the noise stays when i turn left it goes away? Should i try the brake in process for a bit? Not sure what could be causing this?
Thanks
soupE__
Transmission & Drivetrain
Aug 7, 2010 12:09 AM
^AnDre^
Nov 10, 2005 09:31 AM
satan_srv
Oct 8, 2002 12:57 PM
vpc
Jan 20, 2002 08:08 PM
