b20 00 civic ecu question
Old Mar 9, 2008 | 09:19 PM
slo_ej8's Avatar
Default b20 00 civic ecu question
im a little confused about what i need for a b20z into a 2000 civic ej8. i will be running a obd1 p75 ecu, but will i need an adapter harness to make it work? thanks
Old Mar 9, 2008 | 09:23 PM
lluks_844's Avatar
Default Re: b20 00 civic ecu question (slo_ej8)
yeah they call it a step down harness or obd2 to obd1 conversion harness. Why not find a obd2 ls ecu?
Old Mar 9, 2008 | 09:24 PM
slo_ej8's Avatar
Default Re: b20 00 civic ecu question (lluks_844)
so it will be easier to tune with the obd1 ecu.
Old Mar 9, 2008 | 09:28 PM
redclaw05's Avatar
a p75 will make your engine pop, unless its chipped to act like a p72.....the lack of vtec support on the ecu.
switch that as fast as you can. my friends homeboy blew three motors for not changing his ecu and keeping a p75.
but if you really want, i got an OBD2a LS ecu, i am willing to sell for cheap
Old Mar 9, 2008 | 09:34 PM
slo_ej8's Avatar
Default Re: b20 00 civic ecu question (redclaw05)
ok so i need an obd2 to obd1 harness?
Old Mar 9, 2008 | 10:33 PM
7601chexplicit's Avatar
the jumper you need is obd2b to obd 1.........dont rev any higher than 7 and you should be fine
Old Apr 7, 2008 | 11:06 PM
AGENT 99's Avatar
Default Re: b20 00 civic ecu question (7601chexplicit)
So which ecu to use for a b20b into a 98 civic??
Old Apr 7, 2008 | 11:42 PM
Default Re: b20 00 civic ecu question (AGENT 99)
your stock ecu will work fine...you could use a obd1 chipped but you will need obd2a to obd1 jumper
Old Apr 8, 2008 | 12:04 AM
mtber's Avatar
What is a obd2 to obd1 conversion harness?:
A conversion harness is a jumper harness which plugs and plays into an obd2 vehicle and allows you to run an obd1 ecu.
Picture of an obd2 to obd1 conversion harness:
For better performance, you may want to consider chipping the obd1 p75 with a tune/basemap for a b20 setup
Old Apr 8, 2008 | 04:34 AM
AGENT 99's Avatar
Default Re: b20 00 civic ecu question (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
For better performance, you may want to consider chipping the obd1 p75 with a tune/basemap for a b20 setup </TD></TR></TABLE>
Isnt the P75 close enough that it can be run as the b20's ecu for the life of your car?
In other words, whats a chipped p75 going to offer that is really noticeable?
95 iteg
10
Jun 3, 2013 11:36 AM
TehGhett0P1mp
Mar 4, 2009 09:40 PM
big-cat
26
Oct 19, 2006 11:14 AM
StolenTeg
Apr 29, 2004 04:53 AM
