car wont start....whines nd whines
i didnt even know how to begin a search on this......my car has been sittin for a couple of weeks now. i had a bad tranny and finally it finished goin; it stuck in 2nd gear. car sat there but would still start. last week i tryed starting it, it took a bit almost like tha battery was weak, anyways it started but died. i tried to start it again it tha starter started making a different sound, like a RC car sound, not tha signature honda start
. anyways it also seemed like tha battery was diein so i stopped nd left it alone. tryed a few days later nd still had tha weak battery nd rc whine. tryed jumpin tha car today, battery got fully charged, but nothing it just whined alot faster whine tho.
my question is: could this be caused by tha bad tranny? or wut could cause this whine?
ps..i can smell tha gas so i am gettin fuel, nd i do have spark
ppss.. this started when i accidently forgot that cylinder 2 didnt have tha ignition wire in, dont know if that relevent
<U>*****Update*****</U>
ok, i put gas in it and still nothing..i tried a few times, but my battery was weak so i had it hooked up to a home plug in charger, i kept trying because it sounded like it was about to start. After a few more trys, tha starter just stoped making noise all together
now i turn tha key and absolutly nothing happens
.....and i know its not a dead battery because it was still hooked up to tha charger
Modified by StreetRiot_DRE at 7:04 PM 3/14/2008
. anyways it also seemed like tha battery was diein so i stopped nd left it alone. tryed a few days later nd still had tha weak battery nd rc whine. tryed jumpin tha car today, battery got fully charged, but nothing it just whined alot faster whine tho. my question is: could this be caused by tha bad tranny? or wut could cause this whine?
im betting ur timing belt snapped. Check the timing belt or take out the dist cap and see if the rotor turns if not, then u know the timing belt snapped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">im betting ur timing belt snapped. Check the timing belt or take out the dist cap and see if the rotor turns if not, then u know the timing belt snapped.</TD></TR></TABLE>
i get spark, in order...so that would mean my dizzy rotor is spining which would mean my belt has not snapped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRiot_DRE »</TD></TR><TR><TD CLASS="quote">bump 4 some help....</TD></TR></TABLE>
again..
again..
try a junk yard starter...cheap. sounds like the starter gear isnt catching the flywheel. just put in a new starter...its ez.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx_Civic »</TD></TR><TR><TD CLASS="quote">try a junk yard starter...cheap. sounds like the starter gear isnt catching the flywheel. just put in a new starter...its ez. </TD></TR></TABLE>
Word, but im extremely low on cash rite now
nd i can only wonder how much a junk yard will charge....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_07 »</TD></TR><TR><TD CLASS="quote">hmm seem like its your ignitor coil..i had the same problem...jus replace it n bamm ur car is bak in action..lol..</TD></TR></TABLE>
but if thats tha case, WHY and HOW would i be getting Spark??
nd i can only wonder how much a junk yard will charge....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_07 »</TD></TR><TR><TD CLASS="quote">hmm seem like its your ignitor coil..i had the same problem...jus replace it n bamm ur car is bak in action..lol..</TD></TR></TABLE>
you already stated your getting spark so thats definately not the issue, double check to make sure your getting fuel but id put my money on a bad starter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">
you already stated your getting spark so thats definately not the issue, double check to make sure your getting fuel but id put my money on a bad starter</TD></TR></TABLE>
thanks...yeah i think im getting fuel because after trying to crank it for a bit i could smell it, but also i was below tha red on "e" when i stopped using tha car so i'll put some in
lol......yeah thats my fear, that tha starter has gone bad, its always a chain of problems 4 me
..i've been tryin 2 get extra money 4 a trans 4 months now
so if tha starter is bad & its too much 4 another 1, then tha cars goin up 4 sale
.any ideas on how 2 check if tha starter is bad or not? just 2 be possitive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p10hlm »</TD></TR><TR><TD CLASS="quote">NO
What?!?!???
What?!?!???
he is getting spark, thats why i said no
he is getting spark, thats why i said no </TD></TR></TABLE>
oh, tru...does anyone kno how 2 check the starter? :-\ i need 2 make sure that its bad, hope its not
im sure someone on here has a starter laying around that u can pick up cheap. but yea put some gas in it and keep clicking the stater off on off on sometimes it will catch. PS put a post up in the WTB forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">Supply power directly to the starter to test. If it doesn't crank the engine but the battery is fine, then you likely need to replace.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx_Civic »</TD></TR><TR><TD CLASS="quote">im sure someone on here has a starter laying around that u can pick up cheap. but yea put some gas in it and keep clicking the stater off on off on sometimes it will catch. PS put a post up in the WTB forum.</TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRiot_DRE »</TD></TR><TR><TD CLASS="quote">bumb for help with the update
x2
</TD></TR></TABLE>x2
Has it turned over sinced it died on you. Sounds like your just not getting enough power. Let the charger charge the battery for a hour or so. THen try it again or switch a good battery in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det »</TD></TR><TR><TD CLASS="quote">Has it turned over sinced it died on you. Sounds like your just not getting enough power. Let the charger charge the battery for a hour or so. THen try it again or switch a good battery in.</TD></TR></TABLE>
I had the battery hooked up to the charger and pluged in as i messed with the car, the lights and all electrical stuff were as bright as normal and everything that would work with tha key in just the "on" possition worked..except the car did crank at all when i turned the key. I heard the fuel pump priming and the lights on the cluster light up and everything is normal except the motor wont crank at all. My guess it tha starters gone, but i just want to be possitive.
sounds like your batt has low cranking amps. charge it for a couple hrs or overnight. do you have a multimeter? check to see if it's fully charged. have one person check the starter to see if it's getting 12v at the same time the other person is cranking it over
