what axles for gsr motor in 99 civic
Old Mar 9, 2008 | 07:12 PM
Teglessb18's Avatar
Default what axles for gsr motor in 99 civic
I assume any B-series axle will work but I just want to make sure. I have a 99 civic coupe with a b18c1 motor and I need to replace one of the axles. Should I buy one with or without abs? does it even matter?
Old Mar 9, 2008 | 07:25 PM
BlueIntegraBoy's Avatar
Default Re: what axles for gsr motor in 99 civic (Teglessb18)
94-01 Integra, 99-00 Civic Si, or 94-97 Del Sol VTEC. Doesn't matter if it's ABS or not, either will work.
Old Mar 9, 2008 | 07:26 PM
vsmhatched's Avatar
Default Re: what axles for gsr motor in 99 civic (BlueIntegraBoy)
any b-series axles are gonna work for ya
Old Mar 9, 2008 | 07:33 PM
Teglessb18's Avatar
Default Re: what axles for gsr motor in 99 civic (vsmhatched)
Thanks guys but I have another question. Probably a dumb one but do bot axles have to be the same i.e. both from a 99-00 si or can they be a mix and match i.e. one from a gsr and one from an si? I assume since they are interchangable that it wouldnt matter and you could use any como. Just want to make sure before I go buy one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys but I have another question. Probably a dumb one but do bot axles have to be the same i.e. both from a 99-00 si or can they be a mix and match i.e. one from a gsr and one from an si? I assume since they are interchangable that it wouldnt matter and you could use any como. Just want to make sure before I go buy one.</TD></TR></TABLE>
Doesn't matter
Old Mar 9, 2008 | 07:38 PM
Teglessb18's Avatar
Thanks guys. Is the 99-00 si abs or non abs?
Old Mar 9, 2008 | 07:50 PM
B18Chonda's Avatar
i need to replace my axles too - found some good information in here - thanks
Old Mar 9, 2008 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. Is the 99-00 si abs or non abs?</TD></TR></TABLE>
USDM EM1 Si's are non-ABS
Old Mar 9, 2008 | 08:06 PM
Teglessb18's Avatar
Thanks man for all your help
Old Mar 18, 2008 | 01:15 PM
SaraSmiles's Avatar
I was just wondering since you have an Si with a GSR motor. Did you have to change the ECU or anything els when you put in the GSR motor? Or can you keep all of your Si parts besides your motor mounts you have to change. Thanks
beanbag
Dec 26, 2009 05:36 PM
B16b-EJ8
Sep 29, 2006 04:12 PM
sosleepy
Mar 9, 2006 11:16 AM
EG6-SIRII
Sep 28, 2005 07:10 AM
eL
Jan 12, 2005 04:58 AM
