what axles for gsr motor in 99 civic
I assume any B-series axle will work but I just want to make sure. I have a 99 civic coupe with a b18c1 motor and I need to replace one of the axles. Should I buy one with or without abs? does it even matter?
Re: what axles for gsr motor in 99 civic (vsmhatched)
Thanks guys but I have another question. Probably a dumb one but do bot axles have to be the same i.e. both from a 99-00 si or can they be a mix and match i.e. one from a gsr and one from an si? I assume since they are interchangable that it wouldnt matter and you could use any como. Just want to make sure before I go buy one.
Re: what axles for gsr motor in 99 civic (Teglessb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 »</TD></TR><TR><TD CLASS="quote">Thanks guys but I have another question. Probably a dumb one but do bot axles have to be the same i.e. both from a 99-00 si or can they be a mix and match i.e. one from a gsr and one from an si? I assume since they are interchangable that it wouldnt matter and you could use any como. Just want to make sure before I go buy one.</TD></TR></TABLE>
Doesn't matter
Doesn't matter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 »</TD></TR><TR><TD CLASS="quote">Thanks guys. Is the 99-00 si abs or non abs?</TD></TR></TABLE>
USDM EM1 Si's are non-ABS
I was just wondering since you have an Si with a GSR motor. Did you have to change the ECU or anything els when you put in the GSR motor? Or can you keep all of your Si parts besides your motor mounts you have to change. Thanks
