y1 s1 j1 ys1 tranny differences
Old Mar 9, 2008 | 06:59 PM
trianglegreg's Avatar
Default y1 s1 j1 ys1 tranny differences
Could anyone give me a link to a thread that explains the difference between the transmissions. i have a b16a and next year im going to be taking hour long trips to school and back twice a week. i got my motor on hmotors and i got the short geard trans which is the Y1. I wanted to get one of the longer 5th geard trans so my Rpms arent so high and i can get better gas mielage. Is there oging to be much of a difference in the rpms if so how much? Which of the three transmissins have the longest gear ratios and what is a Ys1 and how is it different from the rest? Any infor. will be appreciated.
Old Mar 9, 2008 | 07:03 PM
sirtef9's Avatar
Default Re: y1 s1 j1 ys1 tranny differences (trianglegreg)
I use the 90-91 SI LS trans, never really in 5th, but it's there if needed.
Old Mar 9, 2008 | 07:05 PM
sirtef9's Avatar
Default Re: y1 s1 j1 ys1 tranny differences (sirtef9)
that's also the highest geared trans you have listed, the j1 ys1 and y1 are b16 trans. You can google and find specific specs.
Old Mar 9, 2008 | 07:11 PM
well the transmissions that i listed are compatible with the b16a without any modification right? or there other trans that can just bolt strait up to the b16a1 without changeing anything?
Old Mar 9, 2008 | 07:16 PM
philkehn's Avatar
faq section :thumb up:
Old Mar 9, 2008 | 07:40 PM
Default Re: (philkehn)
The B series Tranny spec links in the FAQ do not work
Old Mar 10, 2008 | 04:24 AM
boostedblkef's Avatar
Default Re: (trianglegreg)
http://technet.ff-squad.com/
Old Mar 10, 2008 | 07:53 AM
1.888'rex's Avatar
Default Re: (boostedblkef)
i have a j1 and my gears are faster than my buddys ys1 i am a little higher rpm than him on the highway 2
ive heard that all b16 tennys and tha integra ks trannys have the same final drive
so u will be aroun the samr rpm
u have a b16 dont worry itll last b16s are rev happy little [freak]ers anyway
i drive my old setup (ger,j1 tranny) all the time @4400 rpm it was fine and if anybody pulled up next 2 me a punch down shift and full throttle away and i was gone!!!!
dont worry about the motor when u drive it drive it like it shoul b but mantiane it offten and properly and itll last
think about it when it was in japan they didnt take the best care of it they bought pulled out and poped vtec! all day du
itll b fine
Old Mar 10, 2008 | 11:31 AM
jdmboyef9's Avatar
Default Re: y1 s1 j1 ys1 tranny differences (eda6)
Your best bet is to go with a 92-93 integra YS1. The down side is you must run a 92-01 clutch but the up side is it has the same internals as most hydro trannys. Right out of the box you have the really tall geared YS1 base tranny and also the GSR YS1 which has better gears similar to a B16 but a taller 5th gear...It's much easier to find parts for the YS1 as opposed to the 90-91 model.
Old Mar 10, 2008 | 11:34 AM
jdmboyef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">I use the 90-91 SI LS trans, never really in 5th, but it's there if needed.</TD></TR></TABLE>
LOL the Integra never came in an SI....maybe an XSi in Japan. USA only got the LS,RS,GS, GSR between 90-93
Old Mar 10, 2008 | 03:30 PM
Gearspeed-Performance's Avatar
Default Re: y1 s1 j1 ys1 tranny differences (jdmboyef9)
Keep in mind that YS-1 and the earlier model transmissions like the J-1, Y-1, S-1 are not interchangeable.
So don't take the gears from a YS-1 and think they will fit in a Y-1....won't work.
As somebody mentioned...It is best to find a USDM GSR YS-1(rare) or a JDM spec Integras XSi YS-1(also rare) and be done with it. You can then take 92-01 Hydro LS 5th gears and use those.
The 5th gears from the USDM 90-91 LS are no longer available. They have been discontinued. So I would invest in a YS-1 if I were you. You will be a lot more happier when it comes time to buy parts.
Good luck finding an parts for a J-1, Y-1...there are no US counterparts to those transmissions and its hard to get them from Japan considering they are over 10 years old and most of the parts are now obsolete
Old Mar 11, 2008 | 11:00 AM
Default Re: y1 s1 j1 ys1 tranny differences (Special Projects MS)
i just found a guy who is parting out a 90 integra and has the LS transmission, he is selling for 100 so im giong to pick it up here pretty soon ive never worked on the insdie of a transmission but there is a pretty good guide in the FAQ, hopefully i can figure it out.
Old Mar 11, 2008 | 11:03 AM
would it matter if its an automatic transmission that im pulling the 5th gear and counter from?
Old Mar 11, 2008 | 11:51 AM
zrickety's Avatar
i don't think they made 5 speed automatics for these cars...
Old Mar 11, 2008 | 11:55 AM
mechmunkee3's Avatar
i just found this when i was looking for info on h2b's, this might help... http://hondaswap.com/swap-arti...9099/
Old Mar 11, 2008 | 01:46 PM
jdmboyef9's Avatar
Default Re: y1 s1 j1 ys1 tranny differences (www.FEOA.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.FEOA.net &raquo;</TD></TR><TR><TD CLASS="quote">i just found this when i was looking for info on h2b's, this might help... http://hondaswap.com/swap-arti...9099/ </TD></TR></TABLE>
Good find
I also have a friend that has 2 extra YS1 B17A GSR trannies. I'm not pricing them but if anyone is interested I can help you locate one
Old Mar 11, 2008 | 01:56 PM
matt94z's Avatar
(would it matter if its an automatic transmission that im pulling the 5th gear and counter from?)
Uhh.... maybe you shouldnt try this yourself haha.
Old Mar 12, 2008 | 12:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trianglegreg &raquo;</TD></TR><TR><TD CLASS="quote">would it matter if its an automatic transmission that im pulling the 5th gear and counter from?</TD></TR></TABLE>
Totally different transmission! Will not work.
B16-CRX
Northeast (Sales)
Oct 18, 2011 01:41 PM
crxdxsir
Mar 28, 2007 04:22 AM
BLUE EH3
Feb 6, 2007 01:50 PM
marieT1GRL
20
Sep 11, 2004 02:13 PM
ewing86
Aug 23, 2004 07:53 PM
