B16a vtec engaging at 7k
Old Mar 9, 2008 | 03:25 PM
D-Atk's Avatar
Default B16a vtec engaging at 7k
Need some help here, basically over the last month or so vtec has been kicking in between 6800-7000rpm. Don't know what happened everything was perfectly fine then one day I noticed it kicked it at 6000rpm. Slowly it would change to 6500 then 6800 now it's at 7000.
I took off the solenoid and checked the screen for dirt none found, I don't know what to check next. I did notice that before I took off the solenoid that it looked like it was leaking some oil so I'm assuming the gasket needs replaced. Would that cause this issue?
Thanks
Denny
Old Mar 9, 2008 | 03:27 PM
SOHC_4dr's Avatar
wouldnt hurt to replace it. a few bucks i think
Old Mar 9, 2008 | 04:00 PM
crxricer66's Avatar
Default Re: (SOHC_4dr)
have you checked your oil?? #1 cause
Old Mar 9, 2008 | 04:16 PM
IndySporty's Avatar
Default Re: (crxricer66)
I've heard something about the spring that causes it to pop out of Vtec on deceleration being sticky or over-active. Just a thought.
Old Mar 9, 2008 | 04:25 PM
D-Atk's Avatar
Default Re: (IndySporty)
Yes I checked the oil and it's fine I check it everytime I fill up just to be safe!
Old Mar 9, 2008 | 04:27 PM
SIred91's Avatar
Rainman
Your piston return springs are out of VTEC fluid.
Old Mar 9, 2008 | 05:30 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">I've heard something about the spring that causes it to pop out of Vtec on deceleration being sticky or over-active. Just a thought.</TD></TR></TABLE>
Lol.
Old Mar 9, 2008 | 06:41 PM
D-Atk's Avatar
Default Re: (Tippyman)
Should I check that along with my blinker fluid....
Old Mar 9, 2008 | 08:15 PM
vtec93accord's Avatar
Could this have anything to do with a vtec pressure switch or no?
tigasin
Nov 14, 2008 11:58 PM
MrRealityman
Apr 28, 2006 08:16 AM
superchargedex
Apr 14, 2005 12:14 PM
DavidT or VajT
Dec 22, 2004 07:30 AM
inzaneN1
Feb 2, 2004 09:24 PM
