too much radiator fluid?
Old Mar 9, 2008 | 02:15 PM
touandcim's Avatar
Default too much radiator fluid?
so my car was overheating after i installed a new radiator. i took the advice of a couple ht guys and opened up my radiator cap, turned the heat on full blast and let the air run itself out of my system. (about 10-15 min.) then i took the car out for a drive and it drove pretty good. i didn't redline but hit the gas pretty hard for a couple pulls. then, it started smelling like radiator fluid and i thought aww f*ck. so i went to pop the hood and it was leaking from the fluid resevoir. the thing looks like a piece of sh*t. but it seemed to work okay holding the fluid. the fluid looked like if overflowed from the resevoir because when i opened it to look in, it was pretty damn full. do i just have too much fluid in my system or what? kinda wierd cuz same thing happened before too. any advice is helpful advice (except for the negative ones.) so lmk!
Old Mar 9, 2008 | 02:26 PM
badboyr66's Avatar
Default Re: too much radiator fluid? (touandcim)
Ever change you stat?
Old Mar 9, 2008 | 03:04 PM
Former User's Avatar
Default Re: too much radiator fluid? (badboyr66)
Did the engine overheat?
Did the new radiator come with a new cap? If not, you may have a faulty radiator cap.
Alternatively, you could have a bad head gasket.
Old Mar 9, 2008 | 03:34 PM
JDM EJ2's Avatar
Radiator Fluid??? Oh you mean ANTIFREEZE...
When you opened the hood, was the antifreeze to the top of the reservoir?
Old Mar 9, 2008 | 05:31 PM
touandcim's Avatar
Default Re: too much radiator fluid? (JDM EJ2)
yeah. it was pretty much at the top, with some kinda overflowed onto whatever was around the resevoir.
touandcim's Avatar
Default Re: too much radiator fluid? (RonJ@HT)
yeah. was a shitty mishimoto radiator. cap doesn't seem to be leaking, but didnt' change out the thermostat and yeah. the car was OVERHEATING during higher load.
Old Mar 10, 2008 | 08:44 AM
touandcim's Avatar
answers bump
Old Mar 10, 2008 | 08:45 AM
touandcim's Avatar
answers bumpr
Old Mar 10, 2008 | 09:11 AM
blk92_d16's Avatar
When you swapped out the radiator, did you reconnect the fan?
Old Mar 10, 2008 | 10:37 PM
touandcim's Avatar
Default Re: (blk92_d16)
yeah. swapped and plugged in the new radiator fan. it seems to work fine.
Old Mar 11, 2008 | 03:33 AM
Black4thgenEF's Avatar
Default Re: (touandcim)
You probably just overfilled your coolant reservoir. If your engine isn't overheating and was fine before the radiator swap, I wouldn't worry. The coolant (like most things) expands when it's hot, that's why you need the coolant reservoir. There are two lines on it, the hot level and cold level. If you had it filled past the cold line while the engine was cold, then some will overflow.
Old Mar 11, 2008 | 05:34 AM
mortificationrock's Avatar
My money is on the T-Stat. Change it 2 see what happens. Its only about $10-15. It won't kill you to change it.
Old Mar 11, 2008 | 08:36 AM
touandcim's Avatar
Default Re: too much radiator fluid? (mortificationrock)
the thermostat is located where the upper radiator hose connects to the motor, correct? when you buy new thermostats, do they come with new o-rings too? j/w.
Old Mar 11, 2008 | 08:37 AM
touandcim's Avatar
answes bump= yet again
Old Mar 11, 2008 | 08:52 AM
Hondaciv95VX's Avatar
Yes its comes with the gaskets..its an easy swap.
Old Mar 11, 2008 | 09:01 AM
Archidictus's Avatar
Unceasing Measure
Default Re: too much radiator fluid? (Hondaciv95VX)
1.) why did you change your radiator to begin with? Was the car overheating with the original unit?
2.) what engine do you have and what state of modification is it in? Is it turbocharged?
3.) did the fluid seem to fill up only when under load or was the antifreeze overflowing when the car was warming up in your driveway?
Old Mar 11, 2008 | 09:51 AM
touandcim's Avatar
Default Re: too much radiator fluid? (Archidictus)
i have a turbocharged b16a2 w/some supporting mods. yeah. the car was overheating before, thought the radiator wasn't efficient enough. maybe that wasn't it though now that i think about it. it would only fill up if it was under load. other than that, sitting in my driveway it seemed perfectly fine.
Old Mar 11, 2008 | 09:55 AM
touandcim's Avatar
bump for my shitty civic
Old Mar 11, 2008 | 09:57 AM
Unceasing Measure
Sounds like a bad head gasket to me.
Old Mar 11, 2008 | 10:10 AM
EK45VTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by touandcim &raquo;</TD></TR><TR><TD CLASS="quote">the thermostat is located where the upper radiator hose connects to the motor, correct? when you buy new thermostats, do they come with new o-rings too? j/w.</TD></TR></TABLE>
thermostat is located where LOWER radiator hose connects to the motor (just below the throttle body)
and radiator cap DOES NOT LEAK when it is in bad shape... it stucks and lets the coolent into the overflow tank but does not allow it to go back into the system...
And with your problem... could be a blown headgasket...
Change the thermostat first... it's cheap and you won't be mad if it doesn't solve your problem cos you won't spend much...
Also try with a new radiator cap... if you have a friend who drives the same car, tra borrowing it from him...
If that doesn't solve your problem then it is defintely the gasket...
if it is the gasket, take off the head resurface it and get a new OEM headgasket (cos "replacement" ones tend to go bad very very soon after installation)
wastro
Dec 10, 2005 12:02 PM
Nightscape
May 14, 2005 07:54 PM
Understeer
Oct 8, 2004 05:27 AM
TJ R
Jan 20, 2003 09:44 PM
TurbothisLS
Oct 6, 2002 05:19 PM
