Bearing Cap Bridge Help
Old Mar 9, 2008 | 12:56 PM
Toanz's Avatar
Default Bearing Cap Bridge Help
I'm in the process of rebuilding my h22a4. I'm down to removing the bottom end components. I just removed the the bolts off the bearing cap bridge, and im having a tough time removing it. It there a special way to get it off? I have the
service manual, but it doesnt really explain how.
Any help would be great.
Thanks
Old Mar 9, 2008 | 01:34 PM
98vtec's Avatar
moderator emeritus
Default Re: Bearing Cap Bridge Help (Toanz)
did you loosen the bolts in the right sequence
you are supposed to loosen them in sequence and in steps.
if you have a deadblow, that will help knock the dowel pins loose.
Old Mar 9, 2008 | 05:34 PM
Toanz's Avatar
yes, i followed the loosening sequence stated in the manual. I tried pulling on and stuff and couldnt get it off. I will try a dead blow tmr.
Old Mar 10, 2008 | 09:17 AM
98vtec's Avatar
moderator emeritus
Default Re: (Toanz)
be easy with the dead blow and try and rock the bridge back and forth gently.
Old Mar 10, 2008 | 12:27 PM
lude98SH's Avatar
Default Re: (98vtec)
i used a small pry bar ,screwdriver and deadblow.
vadimqwe
Transmission & Drivetrain
Mar 12, 2009 10:37 PM
B18CivicHatch
Sep 23, 2007 10:41 PM
turbodelsolman
Nov 10, 2003 03:54 PM
symba
Jun 1, 2003 10:42 AM
D21X
May 23, 2003 07:08 AM
