Rear suspension uneven?????
Old Jul 7, 2002 | 06:27 PM
albert butterbikini's Avatar
New User
Default Rear suspension uneven?????
when measuring from the ground to the edge of the fender on the rear wheels with stock suspension the one side sits slightly higher (about 1/2") than the other. the front measurements come out even. Anyone ever experience this problem before? Air pressure in the tires is equal and the car was measured sitting in a garage on even pavement. when i installed B2 coilovers i had to adjust the collar on the one side to sit 1/2" lower than the other side so the measurements would come out even. any guesses on what would cause this?
Old Jul 7, 2002 | 08:38 PM
Dr Pooface's Avatar
Default Re: Rear suspension uneven????? (JON)
Are you sure the ground you parked on was level?
Old Jul 7, 2002 | 10:01 PM
Tweakmeister's Avatar
Default Re: Rear suspension uneven????? (Ddub)
I've seen this before many times....are you running an aftermarket exhaust? The lighter weight can cause it....
Old Jul 7, 2002 | 10:18 PM
MK Ultra's Avatar
Mine does it too.
Pisses me off. It's the left side that sits lower. Maybe I need to go on a diet.
Old Jul 7, 2002 | 11:19 PM
01CWITR's Avatar
Default Re: Rear suspension uneven????? (MK Ultra)
probarbly no more air in the tire?
Old Jul 7, 2002 | 11:32 PM
Spyglass's Avatar
New User
maybe the amount of gas in the gas tank???
Old Sep 24, 2009 | 10:51 AM
ITR 692's Avatar
i'm bringing this back from the dead. i couldn't find any other thread relating to my issue.
my R is also sitting 1/2 inch lower on the driver's side. i have stock springs. what do you guys think is the problem?
Old Sep 25, 2009 | 07:33 AM
mugenracer's Avatar
I had the same problem when i fitted coilovers, there was approx 0.5" difference with the drivers side being lower. I just screwed the coilover down on the passenger side to match. My last ITR was corner weighted and no two corners were the same height after it (there was only a small difference in each side) but the car drove/handled perfectly.
DARS_C_C
Suspension & Brakes
Feb 26, 2009 10:06 AM
mr. robot-o
Aug 25, 2008 02:04 PM
203_EM2
Honda Civic (2001 - 2005)
Aug 1, 2008 08:19 AM
1hgej1
Suspension & Brakes
18
Nov 17, 2006 10:25 AM
akeldama
Jan 3, 2003 02:04 PM
