Bracke update
Old Mar 9, 2008 | 08:29 AM
ITR 05082's Avatar
Default Brake update
Hi,i will update my Brake on this set
http://cgi.ebay.com/ebaymotors...ZWDVW
Are really much better than oem brake and pad?
Thanks
Old Mar 9, 2008 | 08:47 AM
vtec2nv's Avatar
Default Re: Brake update (ITR 05082)
I would probably go with brembo blanks, or oem with some hawk pads...just my opinion. Im sure some other people will chime in.
Old Mar 9, 2008 | 08:52 AM
Dave_B's Avatar
What intensions do you have with the car? Street only? Track?
I would venture to say if track use is your goal, you'd be better off with some blanks, upgraded pads and some better brake fluid. Another thing you can add to the mix for better braking feel is stainless steel lines.
Old Mar 9, 2008 | 10:56 AM
SuckMyDOHC's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">What intensions do you have with the car? Street only? Track?
I would venture to say if track use is your goal, you'd be better off with some blanks, upgraded pads and some better brake fluid. Another thing you can add to the mix for better braking feel is stainless steel lines.</TD></TR></TABLE>
I'd go with that even for street use
Old Mar 9, 2008 | 11:19 AM
ITR 05082's Avatar
Yes for steet only sometimes for race on Nürnbergring
Old Mar 9, 2008 | 11:37 AM
ITR 05082's Avatar
Default Re: (ITR 05082)
This Brembo for front and rear with OEM Pads,Should be good?
Old Mar 9, 2008 | 11:42 AM
SuckMyDOHC's Avatar
get some blank rotors, Hawk HP+ Pads, SS lines, and ATE Super Blue. Crossdrilled and slotted don't do much other than being more prone to warping and cracking
Old Mar 10, 2008 | 05:33 AM
citrus3000psi's Avatar
steel is steel. If you want to go with bling then get the slotted.
Old Mar 10, 2008 | 08:33 AM
Erik95LS's Avatar
Default Re: (citrus3000psi)
not really an upgrade by any means.
Old Mar 10, 2008 | 08:42 AM
white rocket's Avatar
Default Re: (Erik95LS)
I'm about to install authentic Brembo slotted fronts and Stoptech slotted rears w/ Cobalt GTS pads all around. The rotors are definitely not needed and blanks will work just fine. I just like wasting money .
Braking performance is dictated mostly by the pad chosen along with fluid to raise the boiling point and SS lines for a better pedal feel.
Old Mar 11, 2008 | 08:21 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (white rocket)
I agree that the rotors aren't important, and that the pads and fluid are.
I don't think you need SS lines. People say you need them if you have a spongy brake pedal, because the brake lines are old and bulging. I've never experienced a spongy brake pedal on my ITR, and I have over 6K actual track miles on mine with the original brake lines. My brakes feel fine, including the pedal feel.
Old Mar 11, 2008 | 10:39 AM
Default Re: (nsxtasy)
I suppose you're right. Technically there is nothing wrong with the stock lines at all. If they were to be replaced, however, I would recommend a SS line with the outside protective sheath like Stoptech or Russell. Otherwise dirt and debris could cause a failed/burst line by working its way in through the mesh.
Old Mar 11, 2008 | 12:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
With the SS lines I don't feel as bad letting my calipers hang for a few min while I swaping rotors.
Old Mar 11, 2008 | 01:05 PM
jgirard's Avatar
I just upgraded to Cobalt GT Sports pad front and rear, SS lines, and ATE fluid, will run OEM Autozone rotors
baggelis
Honda S2000
34
Feb 22, 2009 10:19 PM
J T*
Honda S2000
Jun 28, 2004 11:13 PM
natrl
Jun 10, 2003 09:09 PM
OutLaw MR
Sep 11, 2002 08:20 PM
jls_lude
Nov 6, 2001 04:42 PM
