Drivers side motormount bolts spin
Old Mar 8, 2008 | 08:51 PM
MNCRXSi's Avatar
Default Drivers side motormount bolts spin
I am trying to replace the drivers side mount on my 96 Civic and the one bolt came out with no problems, but the other bolt (very front) Just spins, Is there a nut I am missing, or is this thing striped in the frame?
Bolt# 15 on mount# 9.
Old Mar 8, 2008 | 09:12 PM
Luserkid's Avatar
Default Re: Drivers side motormount bolts spin (MNCRXSi)
if its just spinning then you broke the nut. Nothing you could really do. I had to cut the bolt, then a hole to stick my finger in to get the nut out. They are welded to the frame.
Old Mar 8, 2008 | 09:13 PM
viahiptop's Avatar
its stripped ad its also called driverside torque mount. its not really needed if you upgraded your current engine mounts
Old Mar 8, 2008 | 09:18 PM
punkinbeck's Avatar
Default Re: Drivers side motormount bolts spin (viahiptop)
I had to cut a hole in my frame, cut out the old nut, and put in a new one.. you only really need it if you want to do a H or F swap
Old Mar 8, 2008 | 10:00 PM
RS2 FAB's Avatar
Default Re: Drivers side motormount bolts spin (punkinbeck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkinbeck &raquo;</TD></TR><TR><TD CLASS="quote">I had to cut a hole in my frame, cut out the old nut, and put in a new one.. you only really need it if you want to do a H or F swap</TD></TR></TABLE>
or k swap since thats where the passenger side mount bolts onto
Old Mar 9, 2008 | 10:05 AM
MNCRXSi's Avatar
Sounds like we are going to just cut the bolt, and than bolt the new one in using 1 bolt, and weld the other side, If I need to replace it later down the road, I can just cut the welds off.
Old Mar 9, 2008 | 01:47 PM
Syndacate's Avatar
Truth right here.
That's not a motor mount in the sense it holds your motor in, that's just a torque mount that keeps it from rockin too much off/on accel.
They're not needed on a stock B/D engine.
My passenger side torque mount (8) is gone, completely (not quite sure where it went but it took some of the trans case with it), and you can't feel any difference.
EDIT:
PS: In case you're wondering if it was just my car b/c I have a stock Y8, my friend's only rockin 3 mounts on his GSR and hasn't had any problems.
Timreid187
Jun 22, 2016 07:53 PM
cmsoard
Mar 13, 2009 01:35 PM
chickenwing
Sep 15, 2008 09:34 PM
Linh.
25
Sep 24, 2006 06:58 PM
xEGxB18Cx
Jul 5, 2003 05:42 PM
