Engine Flushing?
Old Mar 8, 2008 | 05:26 PM
90 Si Hatch's Avatar
Default Engine Flushing?
has any one ever heard of using Automatic Transmission fluid for flushing out their engine. a friend of mine from my automotive class said something to me one day about doing it and i wasn't sure if any one else has ever tried it???
he said to add a half quart - to one quart of ATF to your engine oil and run it for 5 to 10 minutes then do an oil change.
Any inputs would be nice, Thanks.... Isaac-
Old Mar 8, 2008 | 06:19 PM
EFstyle's Avatar
Default Re: Engine Flushing? (90 Si Hatch)
I work at an oil change shop and we have some Engine flush that we sell and it works great! Its a 4 quart jug. I would recommend doing an engine flush this way... much safer. just get the cleaner, 2 oil filters and your oil... drain out your old oil, change your filter n add the cleaner... let it run for about 5-10 minutes... then drain out the cleaner (run some clean oil through if the oil was real black) then put on your second filter and throw in your oil... crystal clear oil every time!
Old Mar 9, 2008 | 02:14 PM
Default Re: Engine Flushing? (EFstyle)
Any other inputs???
Old Mar 9, 2008 | 03:00 PM
getsome.crx's Avatar
when i blew my head gasket my father used desel. just ran the motor for about 5 min and flushed. used cheep oil and filter. ran for 5 min. changed oil and filter and ran it. he told me that is how they cleaned the motors back in the 60's and 70's.
Old Mar 9, 2008 | 03:41 PM
pluto303's Avatar
Default Re: Engine Flushing? (getsome.crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by getsome.crx &raquo;</TD></TR><TR><TD CLASS="quote">when i blew my head gasket my father used desel. just ran the motor for about 5 min and flushed. used cheep oil and filter. ran for 5 min. changed oil and filter and ran it. he told me that is how they cleaned the motors back in the 60's and 70's.</TD></TR></TABLE>
motors have changed a lot since then dude... idk bout that...
Old Mar 9, 2008 | 04:04 PM
Default Re: Engine Flushing? (pluto303)
Thanks for your input on the desel.
But i am looking more for an answer to my question than something else. Thanks
Old Mar 9, 2008 | 04:12 PM
IndySporty's Avatar
Yeah I used to be a mechanic at the Honda dealership here and we were also an Isuzu dealer.... the 3.5 V6's had a lot of problems with the lifters getting tappy and sticking. That was standard procedure for us when that happened(The recall procedure entailed doing this) We would add 1/2 quart of ATF to the oil and let the engine idle for 30 minutes, then change the oil. ATF is EXTREMELY high-detergent. That's why it's still clean when it comes out of an AT after like 100k miles.
Old Mar 9, 2008 | 04:30 PM
Default Re: Engine Flushing? (This Scene Sucks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I used to be a mechanic at the Honda dealership here and we were also an Isuzu dealer.... the 3.5 V6's had a lot of problems with the lifters getting tappy and sticking. That was standard procedure for us when that happened(The recall procedure entailed doing this) We would add 1/2 quart of ATF to the oil and let the engine idle for 30 minutes, then change the oil. ATF is EXTREMELY high-detergent. That's why it's still clean when it comes out of an AT after like 100k miles. </TD></TR></TABLE>
thats why i am asking, cause tomorrow i am changing my oil and we have tons of AFT laying around in our shop and i thought i'd try it. its not an old motor what so ever, i bought the motor about 6 months ago its a used jdm D15B vtec and i just wanted to clean out the engine some what....
Old Mar 9, 2008 | 04:35 PM
2slow4stock's Avatar
it still has 40-60xxx if not more. They cant 100% be 40,xxx-60,xxx miles without proof. But ither or the engine runs. Just clean it out. I mean the worst it could happen is cleaner internals or better preformance. Good luck with that.
Oh yeah I would just use engine flush, that stuff works great!
76 camaro car
Mar 4, 2016 12:27 PM
mcd7
16
Jun 6, 2011 09:33 PM
oneEg1Tc
Jun 10, 2009 03:20 PM
return_2020
Honda Civic (2001 - 2005)
Sep 2, 2006 06:44 PM
Francesco
Honda S2000
24
Apr 27, 2006 04:51 AM
