what dos it mean whan the inside of the head is looks bronze????????
Old Mar 8, 2008 | 02:02 PM
vtechachey's Avatar
Default what dos it mean whan the inside of the head is looks bronze????????
let me know thx
Old Mar 8, 2008 | 02:04 PM
Eran's Avatar
HT White Ops
It means it's coated in oil and running fine. As long as it doesn't look doo-doo brown.
Old Mar 8, 2008 | 02:08 PM
vtechachey's Avatar
Default Re: what dos it mean whan the inside of the head is looks bronze???????? (vtechachey)
its my boy's car and he said it's bad
Old Mar 8, 2008 | 04:57 PM
StorminMatt's Avatar
It just means that someone used cheap oil and/or let it go for long periods of time without changing the oil. This doesn't happen if you use a good synthetic AND change it often.
Old Mar 8, 2008 | 05:03 PM
.PLUMMM's Avatar
Default Re: what dos it mean whan the inside of the head is looks bronze???????? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">It just means that someone used cheap oil and/or let it go for long periods of time without changing the oil. This doesn't happen if you use a good synthetic AND change it often.</TD></TR></TABLE>
Not exactly. Every head i've seen that has been driven normally and is ready for an oil change, has "dirty" oil. It is a brownish color and there is nothing wrong with it. If it is like black inside or something, you might want to look into it though. No matter if you're using Castrol Syntheitc oil or your local auto store's 10W-30, the oil will be brown and "dirty" if it's been run.
Old Mar 8, 2008 | 05:22 PM
vtechachey's Avatar
Default Re: what dos it mean whan the inside of the head is looks bronze???????? (.PLUMMM)
o ok thx for all of the help
Old Mar 8, 2008 | 05:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .PLUMMM &raquo;</TD></TR><TR><TD CLASS="quote">Not exactly. Every head i've seen that has been driven normally and is ready for an oil change, has "dirty" oil. It is a brownish color and there is nothing wrong with it. If it is like black inside or something, you might want to look into it though. No matter if you're using Castrol Syntheitc oil or your local auto store's 10W-30, the oil will be brown and "dirty" if it's been run.</TD></TR></TABLE>
I'm not talking about the oil itself. I'm talking about those deposits inside the valve cover. If the oil is of low quality and/or not changed frequently, then deposits will be left under the valve cover.
C_H_A_D
12
Jul 10, 2008 04:49 PM
TyPeS-TunEr
12
Mar 22, 2007 06:05 PM
Xxcivic99xX
Aug 4, 2004 07:51 AM
Vouthanack
Jul 30, 2004 11:18 AM
Nextelbuddy
Mar 6, 2004 01:36 PM
