code 41-02 sensor heater
Old Jul 7, 2002 | 04:58 PM
johnzm's Avatar
Default code 41-02 sensor heater
is this part of the O2 sensor? are there other parts involved in this curcut other than the O2 sensor? will the O2 sensor replacement fix this problem???
Old Jul 7, 2002 | 05:19 PM
Chiovnidca's Avatar
Default Re: code 41-02 sensor heater (johnzm)
The O2 sensor has an electrical element built in to heat it up faster on cold starts, and to keep it hot during extended idleing. Checking to see if the resistance of the two heater wires are within spec is the easiest way to be sure it is the problem. (I don't have a manual here, and don't remember the spec.) The O2 is usually the problem, although I have seen a few with bad wires going to the ECU.
slow96lude
Oct 15, 2009 05:07 PM
JasinC19
Oct 11, 2007 09:47 AM
claytonsmith
10
May 16, 2006 12:01 PM
apok
May 16, 2005 09:52 PM
CereaLand
Jun 30, 2004 12:01 PM
