leakdown test results, help!!
Old Mar 8, 2008 | 08:00 AM
civtic's Avatar
Default leakdown test results, help!!
hey, i've just attempted to do a leakdown test using my DIY effort that i made but i think i need a restrictor in the airline to get proper readings...
however.. i can hear air escaping through the filler cap & dispstick tube on all cylinders, about the same amount of air escaping by the sounds of it..
should i hear anything at all coming from the crankcase? i know that the rings will always leak a little, even on new engines but it is usually enough to actually hear it? or is it a case of "if you can hear it, the rings are likely shot!" ??
cheers.
Poey2
Jul 19, 2009 07:38 AM
91' LS-VTEC
Sep 25, 2008 07:41 AM
civtic
Mar 8, 2008 10:59 AM
bigbadboy
May 3, 2007 07:11 PM
