motor mounts
Old Mar 7, 2008 | 11:28 PM
thedao's Avatar
Default motor mounts
what kinda motor mounts should i go with? I have a eg hatch with a jdm b16 in it, or should i just go with inserts?
nix94delsol's Avatar
Default Re: motor mounts (thedao)
Hasport FTMFW
Old Mar 7, 2008 | 11:41 PM
thedao's Avatar
i was reading in other post people were saying that they make a lot of noise and vibrates a lot.
Old Mar 8, 2008 | 12:16 AM
crazyguy's Avatar
Default Re: (thedao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedao &raquo;</TD></TR><TR><TD CLASS="quote">i was reading in other post people were saying that they make a lot of noise and vibrates a lot.</TD></TR></TABLE>
go with oem if u want quiet and smooth
Old Mar 8, 2008 | 12:56 AM
ru7's Avatar
ru7
Default Re: (crazyguy)
Anyone using ES motor mount inserts?
Old Mar 8, 2008 | 05:11 AM
Dasfinc's Avatar
ANY non-stock mount will be a bit louder and vibrate a bit more. I personally FILLED my motor mounts *There are a few articles on it* and it does the same thing as inserts/hasports and is like 1/20th the cost.
Old Mar 8, 2008 | 05:17 AM
SirRevvs's Avatar
Default Re: (Dasfinc)
Even inserts will generate excess vibration but they're cheaper than hasport and will make your factory mounts last longer. I like stock mounts personally, make sure you put on both of the front torque mounts (front trans mount can be found on any 94+ civic integra w/ b series, and the a/c mount that bolts to the block and framerail) I've used the cheap ebay street import mounts on alot of ef swaps and they work great. Don't know if they make them for eg/ek/dc though.
Old Mar 8, 2008 | 05:24 AM
poorhonda's Avatar
get the hasports def the way to go get the 62a there great
bl1tzk1213g
May 16, 2007 10:31 AM
ilovejdmhoes23
Jan 18, 2007 04:32 PM
95GSRT
Jul 28, 2005 04:45 PM
HondaNerd
Jun 20, 2005 07:40 PM
hotdoggies
10
Mar 7, 2005 07:47 AM
