i have a 91 honda civic turn singal dont work
Old Mar 7, 2008 | 10:32 PM
imreal's Avatar
Default i have a 91 honda civic turn signal dont work
i took my dash board out and my turn signal wont work no more my hazzard work what can it be
before it was working before i took it out
Modified by imreal at 11:59 PM 3/7/2008
Old Mar 7, 2008 | 11:36 PM
NOFX's Avatar
H-T White Ops
This should be in the 4G Civic section, not the '92-'00 Civic section.
Figure I might as well bump this for you so when it's moved someone might see it.
Old Mar 8, 2008 | 07:06 AM
Former User's Avatar
Default Re: i have a 91 honda civic turn signal dont work (imreal)
Yeah, wrong section. Anyway, you might have a faulty combination switch on the steering column or, alternatively, the turn signal wiring associated with this switch is disconnected or broken.
Old Mar 8, 2008 | 08:27 AM
grog's Avatar
Default Re: i have a 91 honda civic turn signal dont work (RonJ@HT)
did you plug the hazard switch back in? I think it may need to be plugged in to work.
check out the combination switch also.
Jason DeRonde
Feb 13, 2016 04:26 PM
urtz
Lighting
Aug 23, 2009 06:49 PM
Ls_V_TurboSi
Oct 7, 2006 06:25 PM
Deerslayer
Oct 17, 2004 09:29 AM
