non navi to navi checklist!
hi all i have a 08 si non navi..i want to swap it for navi..i was thinking on the pioneer avic-d3...now i jus need to know exactly what i need to do this..so far i come up with
1.pioneer navi avic-d3
2.the metra double din dash kit or is there a better model for the dash ?
3.honda antenna
4.the bypass amp wire
thats all i came up with..plz help me if i need something else..ty
3.honda antenna
The AVIC-D3 comes with everything you need to make it work.
all you need is the OEM inner panel for the DX or SI/EX w/Nav
For the amp, i dunno if non nav cars came with an external amp...
if it did, i dunno what the wattage is....
maybe you wire it so that the pre-amp outputs go to the amp... but id unno >.>
thanks for quick respone..when u talking about the inner panel do u mean this one...i cant give u direct link but ill give the part number i got at hondapartsdeal
77250-SNA-A01ZA..its called the "PANEL ASSY., CENTER" on the website..and your 100% sure this is all i need besides the avic - d3? kk thank you
AVIC-D3: http://www.crutchfield.com/App..._info
It says the gps ant is in the box...
You also need some brackets and screws...
http://www.8thcivic.com/forums....html
no.. i don't think so... the radio harness should already be in there...
but you do need an OEM -> Aftermarket Wiring Kit
Always use a wiring kit/harness this is so you don't cut into oem wiring.
For the wiring kit for a 06+ Civic FG/FA i dunno what the p/n from metra is.. but you can find them at websites like partsexpress and crutchfield.com
Using an aftermarket deck will disable your steering-wheel mounted radio controls, if you want to use them, you need a converter... specific to your deck and car.
EDIT: also i think you need an ant adapter... because the oem ant isn't motorola fm style any more...
edit: you said you had an si right?? i think it is externally amplified... so you might need to bypass it with a bypass wiring kit, or see if you could hook up the preamps of the avic to the amp...
Modified by bpr0422 at 11:34 PM 3/8/2008
Modified by bpr0422 at 11:43 PM 3/8/2008
yes i do have an si..now to make sure..can u check if i have the things right..ill provide a link of course
1.for the OEM -> Aftermarket Wiring Kit is this it http://www.autotoys.com/x/prod...=7241
2.bypass amp wire http://www.crutchfield.com/App...01727
3.antenna adaptor http://www.crutchfield.com/App...=2569
again ur help is very much apperciated...i jus wanna make sure i get what i need and dont get what i dont need..and the correct items lol...also by any chance would they sell these things at bestbuy..this is proabably where i would be getting it install at..i would much rather do it somewhere else b/c i know they wont bypass the navi but i dont know any good shops in eastern ma that does these things..and 1 more question about the pioneer avic-d3 bypass..now i heard that u have to have ur parking brakes on in order to set destinationa and etc...now the bypass would elminates this correct?
Modified by Dat Fiyahhh at 1:48 PM 3/9/2008
if you are going to have a shop do it....
then why are you going through all the trouble???
If i was having a shop do it, the most i would do is just buy the oem panel and brackets...
cause i want my panels to match...
A respectable shop has all the parts necessary to install the unit... or will get all the right parts to install the unit...
if you were doing it yourself... and have never done it...
imo, buy a unit from crutchfield, cause when you buy a unit from them, they normally include instructions and the wiring that you need with it.
also they provide lifetime support, if you purchased from them.
problem is, the avic-d3 isn't being sold by crutchfield any more.
those seem like the right ones... but like i've said b4 i'm not an expert...
sportyolds
Audio / Security / Video
Sep 26, 2009 10:27 PM
kranked91dx
Jan 24, 2002 03:50 PM
