Dash
I looked around the forum, but couldnt really find anything on the subject.
Im planning on buying a Clock, and the coin pocket for my EG. I was wondering how hard it is to install the clock, and if there are any wirteups on the subject.
Also, for the coin pocket. I know it goes where the dimmer is, but is there any other "buttons" that go next to the dimmer switch? Also, when installing the coin pocket, what do you do with the dimmer switch? ANy links to write ups would be nice.
Thanks
Abius
Thanks
Abius
clock's plug is already chilling behind the block off plate, just plug it in and mount it to the dash.
as for the coin pocket, i pushed the dimmer switch inside the dash and slid the coin pocket it in.
super easy stuff
super easy stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egwhte »</TD></TR><TR><TD CLASS="quote">clock's plug is already chilling behind the block off plate, just plug it in and mount it to the dash.
super easy stuff </TD></TR></TABLE>
x2
Whatever you do, do not leave the dimmer switch unplugged otherwise your dash lights won't come on.
x2
Alright, thanks for the info guys. But does anything other then the dimmer switch go there? Because I think on eBay when you order some fog lights it looks like its the 3 button thing that comes with it instead of the actual fog light button next to the defroster.
Like here :
http://cgi.ebay.ca/92-93-94-95...wItem
Scroll down and look at the picture right next to the relay, its a 3 button panel (what ever you want to call it)
But if I purchase the proper Fog Light switch from say jdmland.com, it would work just as good right?
Thanks
Abius
Modified by Abius at 7:02 PM 3/8/2008
Like here :
Thanks
Abius
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abius »</TD></TR><TR><TD CLASS="quote">Alright, thanks for the info guys. But does anything other then the dimmer switch go there? Because I think on eBay when you order some fog lights it looks like its the 3 button thing that comes with it instead of the actual fog light button next to the defroster.
Like here :
Thanks
Abius
Modified by Abius at 7:02 PM 3/8/2008</TD></TR></TABLE>
If you had an LX trim or higher, there would be a cruise control button. If you had an EX or Si, you would have both cruise control and a moonroof button. I put my OEM foglight switch next to my defroster.
Like here :
Thanks
Abius
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abius »</TD></TR><TR><TD CLASS="quote">Does using an OEM Fog Light button produce any problems if using an aftermarket fog light kit?
Thanks
Most of the time, the aftermarket kits come with the foglight button. Im not too sure about the compatability they have with oem foglight buttons.
Thanks
</TD></TR></TABLE>Most of the time, the aftermarket kits come with the foglight button. Im not too sure about the compatability they have with oem foglight buttons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer »</TD></TR><TR><TD CLASS="quote">
Most of the time, the aftermarket kits come with the foglight button. Im not too sure about the compatability they have with oem foglight buttons.</TD></TR></TABLE>
The OEM and aftermarket switch harnesses are different, therefore, you would need the OEM pigtail if you plan to use the OEM switch.
Some rewiring, and the OEM switch will work on an aftermarket harness. The aftermarket "EG" switch however, resembles more the OEM switch than the "EK" switches to the OEM "EK" switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suno »</TD></TR><TR><TD CLASS="quote">The ebay switch is garbage. And its black so it wont match any other buttons inside.
Get an OEM switch if you can.</TD></TR></TABLE>
All of the "EG" aftermarket switches look gray in the pictures to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">the eg switch from my ebay kit is black as well</TD></TR></TABLE>
The pictures are very deceiving.
Well most of the eBay switches I found to look black. But I picked up a OEM switch from jdmland.com. How hard would re wiring to the OEM switch be? And I picked up a coin pocket, so aftermarket switch is out.
Thanks
Modified by Abius at 1:10 AM 3/10/2008
Thanks
I know this is for a 99-00 Civic, but the wire colors should be the same.
https://honda-tech.com/zerothread?id=2246130
Thanks, ya I bookmarked that when I saw it, thought it would help me. Also since were on the topice of Fog Lights, would these fit aftermarket fog lights?
http://passwordjdm.com/Passwor....aspx
And thanks alot BlueIntegraBoy, your help is much appreciated.
Thanks
Thanks
