PLX M-300 - Narrowband output doesn't satisfy ECU - Random CEL
Old Mar 7, 2008 | 07:11 PM
Legion's Avatar
* B A N N E D *
Default PLX M-300 - Narrowband output doesn't satisfy ECU - Random CEL
Does anyone else have this problem? The PLX narrowband output doesn't fully satisfy my OBD2 ECU. It will work for about 2 weeks at a time, but then I get the "primary O2 sensor" CEL and I have to reset the ECU to clear it. I thought it might be the sensor, so I bought a new one and it didn't help.
Old Mar 8, 2008 | 03:38 AM
GhostAccord's Avatar
Default Re: PLX M-300 - Narrowband output doesn't satisfy ECU - Random CEL (Legion)
Did you install 20 Ohm 10watt resistors in the O2 power and ground wires that go to your ECU?
Old Mar 8, 2008 | 11:57 AM
Legion's Avatar
* B A N N E D *
Default Re: PLX M-300 - Narrowband output doesn't satisfy ECU - Random CEL (GhostAccord)
Yep. But that's a good point, I forgot I even did that. Maybe it's the resistor that's not fooling the ECU?
Old Jun 12, 2011 | 06:36 AM
LightningTeg's Avatar
Community Builder
What pins need the resistor? Just one between the heater/ground circuit?
BoostJockey
23
Feb 7, 2014 04:42 PM
shytdoode
May 20, 2009 03:41 PM
Slammed_am
Jan 9, 2007 09:17 AM
JokerTypeR
Jul 13, 2005 05:15 PM
