Type r piston in gsr
Old Mar 7, 2008 | 05:50 PM
MrViet's Avatar
Default Type r piston in gsr
I don't know if this is a noob question or not but...
is it possible to bore out my gsr cylinders to fit the ITR pistons?
itr pistons are 84 mm right and my gsr is 81mm. i heard that you can't bore out the gsr walls because its too thin...but i dunno... can anyone clarify?
Old Mar 7, 2008 | 06:11 PM
DAneronimo's Avatar
def. a noob question!
nah, im just messing with you. the gsr and itr pistons are both 81mm. itr pistons will swap right into a gsr motor.
good luck!
Old Mar 7, 2008 | 08:36 PM
all-mtr-teg's Avatar
Default Re: Type r piston in gsr (MrViet)
B20 pistons are 84mm, All B18 motors are 81mm stock, whether its a B18A, B18B or B18C1,5, etc.
Old Mar 8, 2008 | 06:25 AM
spooledex's Avatar
Default Re: Type r piston in gsr (all-mtr-teg)
FYI you're dumb
Old Mar 8, 2008 | 06:56 AM
Default Re: Type r piston in gsr (spooledex)
Care to elaborate?
Old Mar 9, 2008 | 08:44 PM
dthug's Avatar
all b series are 81mm execpt the b20 which is 84mm. i wouldn't just "slap" in new pistons w/o honing if your using new piston rings as well.
projcinco
Mar 3, 2008 07:18 PM
vy3tnamezz
Mar 2, 2008 11:42 AM
wrayzor
11
Nov 14, 2007 10:52 AM
94gsr
Aug 31, 2002 01:26 AM
JD_B18CDX
Jul 3, 2002 07:51 AM
