what obd1 ecu will properly run a d16y8 swap in an obd1 car p28 p07 p06
the po7 ecu wont work,(i tried it in my car thinking it might save gas(91 civic convertd to obd1) because of the egr valve of whatever is so special with the emission on the vtec e motor, it threw a code. I believe the po6 will work if you throw in a rpm switch to run the vtec solenoid, otherwise i think you might want the p28
does anyone else know if the p07 will or will not work ... im not looking for guesses im looking for definate answers
thanks for your input btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">does anyone else know if the p07 will or will not work ... im not looking for guesses im looking for definate answers
thanks for your input btw</TD></TR></TABLE>
The P07 will look for an EGR valve and five wire oxygen sensor. It will also ikely run your motor rich since it was designed around 190cc injectors. Although you could possibly make it work, it's not worth the trouble. Stay away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">thanks.... so only option is p28</TD></TR></TABLE>
Correct
Correct
