turbo car, drag radials on front, what tire is best for rear?
Old Mar 7, 2008 | 01:58 PM
B16Civic93's Avatar
Default turbo car, drag radials on front, what tire is best for rear?
car is my second car, dont usually drive it in the rain if i dont have to, what is a good rear tire, 15 inch wheels, i'm getting another set of bfg's for the front (225) what size and brand tire should i get for the rear?
Old Mar 7, 2008 | 03:48 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: turbo car, drag radials on front, what tire is best for rear? (B16Civic93)
If you plan to drive this car on the street with drag radials on the front, then get drag radials for the rear, too.
If you only put the drag radials on when you go to the dragstrip, then get whatever rear tires match the front tires that are on the car the rest of the time.
Old Mar 7, 2008 | 09:01 PM
B16Civic93's Avatar
Default Re: turbo car, drag radials on front, what tire is best for rear? (nsxtasy)
why should i put drag radials all the way around if i have them on the front?
Old Mar 8, 2008 | 07:01 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">why should i put drag radials all the way around if i have them on the front?</TD></TR></TABLE>
Because they will screw up your handling.
Let's say you have sticky drag radials in front, and plain old street tires in the rear. On dry pavement, this will cause a handling condition called "oversteer"; when you go around a curve fast, the rear end will want to swing around on you, causing the car to spin. Hit a wet patch, and the fronts won't grip as well, causing a handling condition called "understeer", in which the car will try to go straight ahead when you turn the wheel.
Mismatched tires are fine for the dragstrip. But not for everyday driving.
Old Mar 9, 2008 | 07:19 AM
B16Civic93's Avatar
well let me ask you this... how come you never see rwd cars riding around with d/r's on all 4? i'm not tryin to argue just understand where your comin from...
Old Mar 9, 2008 | 09:27 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">how come you never see rwd cars riding around with d/r's on all 4?</TD></TR></TABLE>
Because their owners are clueless!
Old Mar 9, 2008 | 02:12 PM
Boner_Ben's Avatar
Four drag radials would be retarded. Just get some regular 195/55 or 205/55 for the rear.
Old Mar 9, 2008 | 03:26 PM
B16Civic93's Avatar
Default Re: turbo car, drag radials on front, what tire is best for rear? (Boner_Ben)
what is a good brand?
Old Mar 11, 2008 | 07:32 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">Four drag radials would be retarded. Just get some regular 195/55 or 205/55 for the rear. </TD></TR></TABLE>
BAD ADVICE. Please don't post UNSAFE advice on the forums.
ShortbusEK
May 22, 2009 12:36 AM
b16bri
Apr 10, 2008 12:54 PM
Teamdiesel
Mar 27, 2006 11:27 AM
ITR9788
Jan 26, 2005 06:02 PM
Short Round
Feb 6, 2004 10:15 PM
