Honda D-series D16Y3
Old Mar 7, 2008 | 01:47 PM
jbleakley's Avatar
Default Honda D-series D16Y3
I have a 1997 Rover with a Honda D-series D16Y3 engine(Honda owned Rover in the1990's). The timing belt snapped at low speed recently (wife driving). I thought initially it was an electrical problem as there was no spark at the spark plugs but when I was preparing to remove the distributor I cranked the engine by hand and I realized the rotor was not turning and so I removed the rocker cover and found the broken timing belt...is the D16Y3 motor an interference or a non-interference motor...can I get away with just replacing the timing belt or do I have to remove the head and check for other damage...I do seem to be able to crank the engine by hand without resistance and there seems no obvious damage under the rocker cover.
Old Mar 7, 2008 | 04:07 PM
StorminMatt's Avatar
Default Re: Honda D-series D16Y3 (jbleakley)
Honda engines are interference engines. So it is entirely possible that you have done some damage to the valves. But without either removing the head and examining them OR changing the timing belt, it is impossible to know. At this point, you might just try replacing the timing belt and doing a compression test. If everything checks out okay here, then you are good to go. Otherwise, you will either need to have the bent valves replaced OR replace the whole head with a known good head.
Peekay2018
Honda CR-V & Element
Nov 27, 2018 12:33 PM
wteebo
Jul 26, 2012 02:33 PM
Jmb106jr
Feb 18, 2011 06:28 AM
katleestephens
Aug 11, 2007 08:31 PM
Tom96Accord
Oct 18, 2004 10:13 AM
